Inleiding
Oh no, the arm of your glasses broke!
If you wear standard-hinge eyeglasses (chances are you probably do), this guide can help. Using only a screwdriver and a replacement arm that can be purchased online or in optical stores, you can get back to seeing in no time!
Wat je nodig hebt
Remove the screw holding the broken arm by turning it counterclockwise.
Één andere persoon heeft deze handleiding voltooid.
