Ga door naar hoofdinhoud
How to Replace a Window Arm for an Out-Swinging Casement Window
Wat je nodig hebt
  1. How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: stap 1, afbeelding 1 van 2 How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: stap 1, afbeelding 2 van 2
    • Unlock the window lock by flipping both switches up until they are pointed horizontally outwards, facing the user.
  2. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 2, afbeelding 1 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 2, afbeelding 2 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 2, afbeelding 3 van 3
    • Pull open all four metal screen latches holding the window screen in place.
    • Place hands on both sides of the screen and lift upwards to remove it.
    • In some cases only two screen latches need to be unlocked for the screen to become loose enough to remove.
  3. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 3, afbeelding 1 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 3, afbeelding 2 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 3, afbeelding 3 van 3
    • Turn the window handle clockwise to open the window.
  4. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 4, afbeelding 1 van 1
    • Use a flathead screwdriver in a clockwise direction to remove the 2.11 mm screw from the bottom of the window handle.
  5. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 5, afbeelding 1 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 5, afbeelding 2 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 5, afbeelding 3 van 3
    • Turn the loosened window handle in either direction to remove it.
  6. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 6, afbeelding 1 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 6, afbeelding 2 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 6, afbeelding 3 van 3
    • Detach the window arm from the track running underneath the window.
    • In most cases window arm has already been detached, so this step would be skipped.
  7. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 7, afbeelding 1 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 7, afbeelding 2 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 7, afbeelding 3 van 3
    • Using a Square #0 screwdriver, remove the four 25.4 mm screws placed on the outside of the window sill.
  8. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 8, afbeelding 1 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 8, afbeelding 2 van 3 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 8, afbeelding 3 van 3
    • Pull the body of the window operator which when removed will vacate a slot.
    • Pull the window arm diagonally through the slot.
  9. How to Replace a Window Arm for an Out-Swinging Casement Window: stap 9, afbeelding 1 van 2 How to Replace a Window Arm for an Out-Swinging Casement Window: stap 9, afbeelding 2 van 2
    • Insert the new window operator into the slot, ensuring it is tightly fit into place.
    • Attach a replacement window arm to the track on the bottom of the window panel.
Conclusie
Nabil Patel
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 101
Altijd: 782
