Ga door naar hoofdinhoud
How to Replace a Watch Strap
Wat je nodig hebt
  1. How to Replace a Watch Strap, Watch Strap: stap 1, afbeelding 1 van 1
    • Begin by laying a soft towel or fabric on a table.
    • This will prevent accidental scratches during the repair.
    • We will be performing all repairs from the back of the watch, to avoid scratching the visible watch face.
  2. How to Replace a Watch Strap: stap 2, afbeelding 1 van 2 How to Replace a Watch Strap: stap 2, afbeelding 2 van 2
    • Before you begin, consider practicing with your tool to compress the bar.
    • Hold the watch with the face in your palm, with one end of the strap free to move.
  3. How to Replace a Watch Strap: stap 3, afbeelding 1 van 2 How to Replace a Watch Strap: stap 3, afbeelding 2 van 2
    • Insert your Spring Bar tool into the gap between the end of the watch strap and the watch body.
    • Press down and compress the spring. By pushing the bar away from the body, one end of the spring bar should come loose.
  4. How to Replace a Watch Strap: stap 4, afbeelding 1 van 2 How to Replace a Watch Strap: stap 4, afbeelding 2 van 2
    • Being cautious as to not damage the body or spring bar, slide the bar out from its hole and remove the strap.
    • Set this half of the strap with the spring bar aside until we remove the other strap.
  5. How to Replace a Watch Strap: stap 5, afbeelding 1 van 3 How to Replace a Watch Strap: stap 5, afbeelding 2 van 3 How to Replace a Watch Strap: stap 5, afbeelding 3 van 3
    • Repeat steps 2-4 to remove the other end of the watch strap.
  6. How to Replace a Watch Strap: stap 6, afbeelding 1 van 3 How to Replace a Watch Strap: stap 6, afbeelding 2 van 3 How to Replace a Watch Strap: stap 6, afbeelding 3 van 3
    • Replace the old or damaged watch straps by simply sliding the spring bars out and into the new straps
    • Be careful not to put the new straps on the wrong side of the body.
  7. How to Replace a Watch Strap: stap 7, afbeelding 1 van 3 How to Replace a Watch Strap: stap 7, afbeelding 2 van 3 How to Replace a Watch Strap: stap 7, afbeelding 3 van 3
    • Begin the reassembly by sliding the bottom of the spring bar into its hole on the watch body.
    • Remember, always work from the back of the watch to prevent visible scratches.
    • Using your spring bar tool, compress the bar and slide back into place.
    • The spring bar should click when installed correctly.
  8. How to Replace a Watch Strap: stap 8, afbeelding 1 van 3 How to Replace a Watch Strap: stap 8, afbeelding 2 van 3 How to Replace a Watch Strap: stap 8, afbeelding 3 van 3
    • Repeat step 7 on the other side of the watch.
    • Give the watch a tug to make sure all parts are installed correctly.
Conclusie
You have completed the fix! We hope this guide has helped.
6 andere personen hebben deze handleiding voltooid.
domenicruffino
308 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-2, Green Fall 2015 Lid van Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 69
Altijd: 11,765
