Ga door naar hoofdinhoud
How to Replace a Toilet's Shut-Off Valve
Wat je nodig hebt
  1. How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: stap 1, afbeelding 1 van 2 How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: stap 1, afbeelding 2 van 2
    • Locate the water main line (typically found in your basement).
    • Turn off the water main line by rotating the knob clockwise.
  2. How to Replace a Toilet's Shut-Off Valve: stap 2, afbeelding 1 van 2 How to Replace a Toilet's Shut-Off Valve: stap 2, afbeelding 2 van 2
    • Go to the lowest level of your house and turn the faucet on at any sink.
    • Keep the faucet running until it stops spewing water. If the faucet doesn't stop, you likely turned the wrong valve in Step 1.
  3. How to Replace a Toilet's Shut-Off Valve: stap 3, afbeelding 1 van 1
    • Flush the toilet (the one that needs the valve to be replaced).
  4. How to Replace a Toilet's Shut-Off Valve: stap 4, afbeelding 1 van 2 How to Replace a Toilet's Shut-Off Valve: stap 4, afbeelding 2 van 2
    • Turn the toilet shut off valve counter clockwise.
  5. How to Replace a Toilet's Shut-Off Valve: stap 5, afbeelding 1 van 2 How to Replace a Toilet's Shut-Off Valve: stap 5, afbeelding 2 van 2
    • Using the wrench, disconnect the tank hose from the pipe by turning the wrench clockwise until the hose is completely disconnected from the pipe.
  6. How to Replace a Toilet's Shut-Off Valve: stap 6, afbeelding 1 van 2 How to Replace a Toilet's Shut-Off Valve: stap 6, afbeelding 2 van 2
    • Rotate the toilet shut-off valve clockwise with the wrench until the valve comes off from the pipe.
    • Slide the new valve onto the pipe and tighten the valve onto the pipe with the wrench.
    • Using the wrench reconnect the hose to the pipe by rotating the wrench counter clockwise.
    • Turn the water main on rotating the knob counter clockwise.
Eindstreep
Jayden Scott-Douglas
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 79
Altijd: 3,128
