Ga door naar hoofdinhoud
How to Replace a Three-Prong Plug on a Power Strip
Wat je nodig hebt
  1. How to Replace a Three-Prong Plug on a Power Strip, Three-Pole Plug: stap 1, afbeelding 1 van 1
    • Unplug the power strip and place it on a flat, non-metal surface.
  2. How to Replace a Three-Prong Plug on a Power Strip: stap 2, afbeelding 1 van 2 How to Replace a Three-Prong Plug on a Power Strip: stap 2, afbeelding 2 van 2
    • Cut near the base of the original plug, all the way through. Dispose of the old plug.
  3. How to Replace a Three-Prong Plug on a Power Strip: stap 3, afbeelding 1 van 1
    • Before attempting to work with the wires, insert the cord into a piece of heat shrink tubing. This will help to safely seal the wires later.
  4. How to Replace a Three-Prong Plug on a Power Strip: stap 4, afbeelding 1 van 2 How to Replace a Three-Prong Plug on a Power Strip: stap 4, afbeelding 2 van 2
    • Examine the 3 wires inside. You should see green, white, and black. Snip off any stray wires over a trash can.
  5. How to Replace a Three-Prong Plug on a Power Strip: stap 5, afbeelding 1 van 1
    • Strip back about 1/2 inch of the Wire with the wire strippers.
    • Braid the wires by gently twisting each strand so they stay with their same color wires.
  6. How to Replace a Three-Prong Plug on a Power Strip: stap 6, afbeelding 1 van 1
    • Unscrew the hinge on the new plug, set the screw somewhere safe for later.
  7. How to Replace a Three-Prong Plug on a Power Strip: stap 7, afbeelding 1 van 1
    • Make sure you have 3 different colored screws. Gold or dark colored, green and silver or light colored.
  8. How to Replace a Three-Prong Plug on a Power Strip: stap 8, afbeelding 1 van 3 How to Replace a Three-Prong Plug on a Power Strip: stap 8, afbeelding 2 van 3 How to Replace a Three-Prong Plug on a Power Strip: stap 8, afbeelding 3 van 3
    • Pair the black wire to the gold or dark colored screw. Once twisted around the screw clockwise, tighten it.
    • Pair the green wire to the green colored screw. Once twisted around the screw clockwise tighten it.
    • Pair the white wire to the silver or light colored screw. Once twisted around the screw clockwise, tighten it.
  9. How to Replace a Three-Prong Plug on a Power Strip: stap 9, afbeelding 1 van 3 How to Replace a Three-Prong Plug on a Power Strip: stap 9, afbeelding 2 van 3 How to Replace a Three-Prong Plug on a Power Strip: stap 9, afbeelding 3 van 3
    • Close up the new plug and screw it tightly shut.
    • Make sure the plug closes well with the cables and it is not blocking the closing mechanism.
  10. How to Replace a Three-Prong Plug on a Power Strip: stap 10, afbeelding 1 van 3 How to Replace a Three-Prong Plug on a Power Strip: stap 10, afbeelding 2 van 3 How to Replace a Three-Prong Plug on a Power Strip: stap 10, afbeelding 3 van 3
    • Seal the Heat Shrink Tubing by holding the flame of a lighter directly on the tubing, moving it back and forth until the tubing molds itself to the wires.
    • Do not let the flame linger for too long, or you run the risk of ruining the seal.
    • If heat shrink is unavailable, electrical tape works just as well.
  11. How to Replace a Three-Prong Plug on a Power Strip: stap 11, afbeelding 1 van 2 How to Replace a Three-Prong Plug on a Power Strip: stap 11, afbeelding 2 van 2
    • Connect to the wall and enjoy your restored power strip.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 67
Altijd: 3,770
