Ga door naar hoofdinhoud
How to Replace a Tail Light for a 2011-2015 Ford Explorer
Wat je nodig hebt
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: stap 1, afbeelding 1 van 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: stap 1, afbeelding 2 van 2
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 2, afbeelding 1 van 1
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 3, afbeelding 1 van 1
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 4, afbeelding 1 van 1
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 5, afbeelding 1 van 1
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 6, afbeelding 1 van 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 6, afbeelding 2 van 2
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 7, afbeelding 1 van 1
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 8, afbeelding 1 van 1
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 9, afbeelding 1 van 1
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: stap 10, afbeelding 1 van 1
    • Gently place the new bulb in the bulb socket.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Michael Lynch
344 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-4, Green Fall 2015 Lid van Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Leden
17 handleidingen geschreven
1Gids Commentaar
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 110
Altijd: 24,251
