Ga door naar hoofdinhoud
How to Replace a Speaker on a Yamaha PSS-130 Keyboard
Wat je nodig hebt
  1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: stap 1, afbeelding 1 van 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: stap 1, afbeelding 2 van 2
    • Remove the battery cover.
    • Remove all twelve of the 9.0 mm screws on the back cover of the device's casing using a Phillips #1 screwdriver.
  2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 2, afbeelding 1 van 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 2, afbeelding 2 van 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 2, afbeelding 3 van 3
    • Place your fingers in the battery compartment, and place your thumb on the back of the keyboard.
    • Grip inside battery cover and push on the back of the keyboard with your thumb.
  3. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 3, afbeelding 1 van 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 3, afbeelding 2 van 2
    • Replace two 9.0 mm Phillips screws to keep the keys from falling out while working on this device.
  4. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 4, afbeelding 1 van 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 4, afbeelding 2 van 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 4, afbeelding 3 van 3
    • Rotate the keyboard to get a better angle with the soldering iron.
  5. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 5, afbeelding 1 van 1
    • Desolder the connections of the old speaker using the soldering iron and the solder wick.
  6. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 6, afbeelding 1 van 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 6, afbeelding 2 van 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 6, afbeelding 3 van 3
    • Remove the fasteners using an 11 mm socket wrench.
    • It will take very little torque to strip the plastic, so make sure that your wrench is turning them to the left.
  7. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 7, afbeelding 1 van 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 7, afbeelding 2 van 2
    • The speaker should now be free. Simply lift the speaker out.
    • Using the same process, place the new speaker in the speaker indentation.
    • My own speaker was not malfunctioning so I did not replace it.
  8. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 8, afbeelding 1 van 1
    • Replace the fasteners that were removed in step 6, this time tightening to the right.
  9. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: stap 9, afbeelding 1 van 1
    • Solder the new speaker to the wires taken off in step 5.
Conclusie
To reassemble your device, follow these instructions in reverse order from step 3.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 533
