Ga door naar hoofdinhoud
How to Replace a Screen Protector on an iPhone 12
Wat je nodig hebt
  1. How to Replace a Screen Protector on an iPhone 12, Screen Protector: stap 1, afbeelding 1 van 3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: stap 1, afbeelding 2 van 3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: stap 1, afbeelding 3 van 3
    • If you already have a pre-existing screen protector, you will gently peel of your existing screen protector from the top of you iPhone.
    • If any small pieces of the screen protector are still attached to the phone, genlty peel the pieces off until no more pieces remain.
    • When the screen protector and the pieces are removed, you can dispose of it immediately or set it aside for disposal.
  2. How to Replace a Screen Protector on an iPhone 12: stap 2, afbeelding 1 van 3 How to Replace a Screen Protector on an iPhone 12: stap 2, afbeelding 2 van 3 How to Replace a Screen Protector on an iPhone 12: stap 2, afbeelding 3 van 3
    • Grab the wet cloth from the pack and wipe the screen of the iPhone in order to remove any stain or mark left behind.
  3. How to Replace a Screen Protector on an iPhone 12: stap 3, afbeelding 1 van 2 How to Replace a Screen Protector on an iPhone 12: stap 3, afbeelding 2 van 2
    • With the LCD cloth, wipe and dry the screen of the phone to remove any small debris or dust.
  4. How to Replace a Screen Protector on an iPhone 12: stap 4, afbeelding 1 van 3 How to Replace a Screen Protector on an iPhone 12: stap 4, afbeelding 2 van 3 How to Replace a Screen Protector on an iPhone 12: stap 4, afbeelding 3 van 3
    • Grab the dust sticker and apply it all around on the screen multiple times, until you covered all areas of the iPhone display.
  5. How to Replace a Screen Protector on an iPhone 12: stap 5, afbeelding 1 van 3 How to Replace a Screen Protector on an iPhone 12: stap 5, afbeelding 2 van 3 How to Replace a Screen Protector on an iPhone 12: stap 5, afbeelding 3 van 3
    • Grab the screen protector and remove the plastic that's attached to the sticky part of the screen protector.
    • Align the new screen protector to the iPhone without touching the sticky part.
    • Press down on the screen protector from the top of the iPhone until you reach the bottom.
  6. How to Replace a Screen Protector on an iPhone 12: stap 6, afbeelding 1 van 3 How to Replace a Screen Protector on an iPhone 12: stap 6, afbeelding 2 van 3 How to Replace a Screen Protector on an iPhone 12: stap 6, afbeelding 3 van 3
    • With the new screen protector on the phone, use the anti-bubble card to prevent bubbles from staying in between the iPhone and the screen protector.
    • Push the bubbles towards the edge of the iPhone until you see no more on the screen.
  7. How to Replace a Screen Protector on an iPhone 12: stap 7, afbeelding 1 van 1
    • With the bubbles removed from the screen, the new screen protector for the iPhone 12 is now installed.
    • Dispose of any waste left after the installation.
Conclusie
reveleszacatecas5
145 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 8-3, Ribeiro Fall 2023 Lid van CSU Los Angeles, Team 8-3, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S8G3
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 195
Altijd: 711
