Ga door naar hoofdinhoud
How to Replace a Sash Window Lock
Wat je nodig hebt
  1. How to Replace a Sash Window Lock, Window Lock: stap 1, afbeelding 1 van 2 How to Replace a Sash Window Lock, Window Lock: stap 1, afbeelding 2 van 2
    • Measure the length between the two screws on the lock.
    • Measure the width of the lock from the screw to the keeper.
    • These measurements help determine the size of lock you will need.
  2. How to Replace a Sash Window Lock: stap 2, afbeelding 1 van 3 How to Replace a Sash Window Lock: stap 2, afbeelding 2 van 3 How to Replace a Sash Window Lock: stap 2, afbeelding 3 van 3
    • Move the lock into a neutral position.
    • Remove the 12.7 mm screw on the left side of the lock with a Phillips #2 screwdriver.
  3. How to Replace a Sash Window Lock: stap 3, afbeelding 1 van 3 How to Replace a Sash Window Lock: stap 3, afbeelding 2 van 3 How to Replace a Sash Window Lock: stap 3, afbeelding 3 van 3
    • Remove the 12.7 mm Phillips #2 screw on the right side of the lock.
    • Remove the lock.
  4. How to Replace a Sash Window Lock: stap 4, afbeelding 1 van 3 How to Replace a Sash Window Lock: stap 4, afbeelding 2 van 3 How to Replace a Sash Window Lock: stap 4, afbeelding 3 van 3
    • Remove the left 12.7 mm screw on the lock keeper with a Phillips #2 screwdriver.
  5. How to Replace a Sash Window Lock: stap 5, afbeelding 1 van 2 How to Replace a Sash Window Lock: stap 5, afbeelding 2 van 2
    • Remove the right 12.7 mm Phillips #2 screw on the lock keeper.
    • The lock keeper will fall off of the window once the last screw is removed. Be ready to catch it!
  6. How to Replace a Sash Window Lock: stap 6, afbeelding 1 van 3 How to Replace a Sash Window Lock: stap 6, afbeelding 2 van 3 How to Replace a Sash Window Lock: stap 6, afbeelding 3 van 3
    • Line up the new lock keeper with the existing holes in the window.
    • Hold the keeper in place while inserting and tightening both the left and right 12.7 mm Phillips screws with a Phillips #2 screwdriver.
  7. How to Replace a Sash Window Lock: stap 7, afbeelding 1 van 3 How to Replace a Sash Window Lock: stap 7, afbeelding 2 van 3 How to Replace a Sash Window Lock: stap 7, afbeelding 3 van 3
    • Line up the new lock with the existing holes.
    • Hold the new lock in place while inserting and tightening the right 12.7 mm screw with a Phillips #2 screwdriver.
  8. How to Replace a Sash Window Lock: stap 8, afbeelding 1 van 3 How to Replace a Sash Window Lock: stap 8, afbeelding 2 van 3 How to Replace a Sash Window Lock: stap 8, afbeelding 3 van 3
    • Put the lock into a locked position.
    • Hold the new lock in place while inserting and tightening the left 12.7 mm Phillips #2 screw.
    • The new lock is now ready to be used!
Conclusie
Seb S
157 Reputatie
1 Handleiding geschreven
1Gids Commentaar
This replacement of sash hardware information is really fantastic, know I want to say that it's really appreciated, We also are providing builder hardware if you want in bulk. You can contact us
BuilderHardwarwe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 46
Altijd: 4,846
