Ga door naar hoofdinhoud
How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: stap 1, afbeelding 1 van 2 How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: stap 1, afbeelding 2 van 2
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: stap 2, afbeelding 1 van 2 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 2, afbeelding 2 van 2
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: stap 3, afbeelding 1 van 2 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 3, afbeelding 2 van 2
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: stap 4, afbeelding 1 van 3 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 4, afbeelding 2 van 3 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 4, afbeelding 3 van 3
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: stap 5, afbeelding 1 van 2 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 5, afbeelding 2 van 2
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: stap 6, afbeelding 1 van 2 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 6, afbeelding 2 van 2
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: stap 7, afbeelding 1 van 2 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 7, afbeelding 2 van 2
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: stap 8, afbeelding 1 van 3 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 8, afbeelding 2 van 3 How to Replace a Nequare Cordless Vacuum S182 Filter: stap 8, afbeelding 3 van 3
    • Put the black part back into the canister and put in the new filter.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Oghenefejiro Egede
181 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 49
Altijd: 1,271
