Ga door naar hoofdinhoud
How to Replace a Guess W0016L2 Watch Battery
Wat je nodig hebt
  1. How to Replace a Guess W0016L2 Watch Battery, Watch Battery: stap 1, afbeelding 1 van 3 How to Replace a Guess W0016L2 Watch Battery, Watch Battery: stap 1, afbeelding 2 van 3 How to Replace a Guess W0016L2 Watch Battery, Watch Battery: stap 1, afbeelding 3 van 3
    • Press the buttons on the sides of the watch clasp to release the latch.
    • Open the watch clasp.
  2. How to Replace a Guess W0016L2 Watch Battery: stap 2, afbeelding 1 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 2, afbeelding 2 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 2, afbeelding 3 van 3
    • Place the watch on its side.
    • Use a pin tool to push the clasp pin out from the side and remove it.
  3. How to Replace a Guess W0016L2 Watch Battery: stap 3, afbeelding 1 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 3, afbeelding 2 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 3, afbeelding 3 van 3
    • Align the tip of the huaxing tool with the notches on the back case of the watch.
    • Once the huaxing tool is aligned with the notches on the back of the watch, turn it counterclockwise to unscrew the back case.
  4. How to Replace a Guess W0016L2 Watch Battery: stap 4, afbeelding 1 van 2 How to Replace a Guess W0016L2 Watch Battery: stap 4, afbeelding 2 van 2
    • Use tweezers or a spudger to remove the plastic guard covering the battery.
  5. How to Replace a Guess W0016L2 Watch Battery: stap 5, afbeelding 1 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 5, afbeelding 2 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 5, afbeelding 3 van 3
    • Use a spudger to gently lift the battery clip just enough to slide the battery out from the holder.
    • If you're using tweezers, simply remove the battery.
  6. How to Replace a Guess W0016L2 Watch Battery: stap 6, afbeelding 1 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 6, afbeelding 2 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 6, afbeelding 3 van 3
    • Use tweezers or your hands to place the new battery into the battery slot with the positive side facing upwards.
  7. How to Replace a Guess W0016L2 Watch Battery: stap 7, afbeelding 1 van 2 How to Replace a Guess W0016L2 Watch Battery: stap 7, afbeelding 2 van 2
    • Set the plastic guard back in place by aligning it with the stems of the crown.
  8. How to Replace a Guess W0016L2 Watch Battery: stap 8, afbeelding 1 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 8, afbeelding 2 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 8, afbeelding 3 van 3
    • Replace the back case of the watch.
    • Align the watch case opener with the notches on the back case and turn it clockwise to tighten.
  9. How to Replace a Guess W0016L2 Watch Battery: stap 9, afbeelding 1 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 9, afbeelding 2 van 3 How to Replace a Guess W0016L2 Watch Battery: stap 9, afbeelding 3 van 3
    • Insert the pin into the watch link.
    • Slide the pin into one of the holes of the clasp.
    • Push the pin down and place it under the second hole of the clasp.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Hassaan Bashir
199 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 22
Altijd: 345
