Ga door naar hoofdinhoud
How to Replace a Coffee Tabletop Glass
Wat je nodig hebt
  1. How to Replace a Coffee Tabletop Glass, Coffee Table Glass: stap 1, afbeelding 1 van 2 How to Replace a Coffee Tabletop Glass, Coffee Table Glass: stap 1, afbeelding 2 van 2
    • Flip the coffee table base upside down on an empty area.
  2. How to Replace a Coffee Tabletop Glass: stap 2, afbeelding 1 van 1
    • Use a cleaning spray to clean the surface of the glass table.
    • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
  3. How to Replace a Coffee Tabletop Glass: stap 3, afbeelding 1 van 2 How to Replace a Coffee Tabletop Glass: stap 3, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
    • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
    • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
  4. How to Replace a Coffee Tabletop Glass: stap 4, afbeelding 1 van 2 How to Replace a Coffee Tabletop Glass: stap 4, afbeelding 2 van 2
    • Remove the coffee table legs piece by piece.
  5. How to Replace a Coffee Tabletop Glass: stap 5, afbeelding 1 van 1
    • Remove the glass.
    • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
  6. How to Replace a Coffee Tabletop Glass: stap 6, afbeelding 1 van 1
    • Replace the broken/ damaged glass with the new one.
Conclusie
Jasrin Kaur
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 46
Altijd: 2,314
