Ga door naar hoofdinhoud
How to Replace a 2017 Honda HR-V Smart Key Battery
Wat je nodig hebt
  1. How to Replace a 2017 Honda HR-V Smart Key Battery, Opening key fob: stap 1, afbeelding 1 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Opening key fob: stap 1, afbeelding 2 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Opening key fob: stap 1, afbeelding 3 van 3
    • Turn key over so "H" is in your view.
    • Swipe the small switch below the "H" to the right while holding the key with both hands.
  2. How to Replace a 2017 Honda HR-V Smart Key Battery, Taking key out of key fob: stap 2, afbeelding 1 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking key out of key fob: stap 2, afbeelding 2 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking key out of key fob: stap 2, afbeelding 3 van 3
    • Slide the valet key out from the remote.
    • Insert the valet key in between the two black rectangles on the edge of the remote.
    • Turn the key to the right to pry the two parts open.
  3. How to Replace a 2017 Honda HR-V Smart Key Battery, Taking battery out: stap 3, afbeelding 1 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking battery out: stap 3, afbeelding 2 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking battery out: stap 3, afbeelding 3 van 3
    • The valet key shell will split into two parts.
    • Using minimal force take the battery out with your finger or a plastic prying tool.
    • Lift the battery out.
  4. How to Replace a 2017 Honda HR-V Smart Key Battery, Replacing battery: stap 4, afbeelding 1 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Replacing battery: stap 4, afbeelding 2 van 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Replacing battery: stap 4, afbeelding 3 van 3
    • Insert the new battery by putting the bottom of battery in big teeth first.
    • Push the top of the battery into place.
  5. How to Replace a 2017 Honda HR-V Smart Key Battery, Putting key fob back together: stap 5, afbeelding 1 van 2 How to Replace a 2017 Honda HR-V Smart Key Battery, Putting key fob back together: stap 5, afbeelding 2 van 2
    • Push the two halves of the key together.
    • Align the edges and seal it in place by pressing the sides of the shell together.
  6. How to Replace a 2017 Honda HR-V Smart Key Battery, Inserting key back into key fob: stap 6, afbeelding 1 van 2 How to Replace a 2017 Honda HR-V Smart Key Battery, Inserting key back into key fob: stap 6, afbeelding 2 van 2
    • Insert the valet key back into the designated slot opposite of the silver loop.
    • Smart key battery is replaced and ready to use!
Conclusie
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Easy-to-use guide, I didn't even know that there was a key inside of the fob...Great demo on a do it yourself and save yourself money that is needed else where...Thank you for sharing....
Jannette Needs - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 44
Afgelopen 7 dagen: 195
Afgelopen 30 dagen: 773
Altijd: 13,539
