Ga door naar hoofdinhoud
How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22
Wat je nodig hebt
  1. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22, Windsshiled Wiper blades.: stap 1, afbeelding 1 van 2 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22, Windsshiled Wiper blades.: stap 1, afbeelding 2 van 2
    • Put the wipers in service position. To do that you must get into the vehicle.
    • Then push the ignition button ON and OFF.
    • Push the wiper stock down once which will lift your wiper arms.
  2. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 2, afbeelding 1 van 3 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 2, afbeelding 2 van 3 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 2, afbeelding 3 van 3
    • After you are done with your first step your wiper blades position should be up as shown in the image.
    • Once they are in the service position lift the wiper blades to about 120 degree.
  3. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 3, afbeelding 1 van 1
    • Place a towel or piece of rough cloth on the windshield.
    • Placing towel on windscreen helps protect windshield from the metal wiper arms as they are spring-loaded.
  4. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 4, afbeelding 1 van 3 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 4, afbeelding 2 van 3 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 4, afbeelding 3 van 3
    • Remove the old wiper blade by pressing the little square button on the wiper mounting arm.
    • Keep pressing the button while lifting the wiper blade in the direction of the wiper arm and pull the wiper blade away from the arm.
    • Remember this step might require a bit of pressure.
  5. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 5, afbeelding 1 van 1
    • After the blade is removed gently place back the wiper arms on the windscreen.
  6. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 6, afbeelding 1 van 3 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 6, afbeelding 2 van 3 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 6, afbeelding 3 van 3
    • Now take the new wiper blade and sliding directly into the wiper arm mount. You will hear a click once the new blade has been mounted properly.
    • Make sure the new wiper blades latches perfectly with the mount.
  7. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: stap 7, afbeelding 1 van 1
    • Remove the cloth from the windshield and place your wipers gently onto the windscreen.
Conclusie
You can follow the same steps for the other wiper arm. Also make sure to check the wipers before hitting the road.
Yashkumar Patel
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 80
Altijd: 981
