Ga door naar hoofdinhoud
How to Replace Underside Fabric of a Chair
Wat je nodig hebt
  1. How to Replace Underside Fabric of a Chair, Underside Fabric: stap 1, afbeelding 1 van 1
    • Turn the armchair on its back.
  2. How to Replace Underside Fabric of a Chair: stap 2, afbeelding 1 van 1
    • Use pliers to remove the staples from the chair frame.
    • If the staples are too difficult to remove, cut away the fabric with scissors.
  3. How to Replace Underside Fabric of a Chair: stap 3, afbeelding 1 van 1
    • Measure out the dimensions of the perimeter of the chair frame.
    • Add an extra inch to each side to allow for error.
  4. How to Replace Underside Fabric of a Chair: stap 4, afbeelding 1 van 2 How to Replace Underside Fabric of a Chair: stap 4, afbeelding 2 van 2
    • Trace the dimensions onto the new fabric.
    • Cut along the traced lines.
  5. How to Replace Underside Fabric of a Chair: stap 5, afbeelding 1 van 1
    • Fold under approximately a 1-inch allowance from the fabric’s edges.
    • Adjust the folded edges as needed to the correct size.
  6. How to Replace Underside Fabric of a Chair: stap 6, afbeelding 1 van 2 How to Replace Underside Fabric of a Chair: stap 6, afbeelding 2 van 2
    • Use a staple gun to staple the fabric to the chair frame starting at one corner.
    • If the staples do not go all the way into the chair frame, tap lightly with a hammer.
  7. How to Replace Underside Fabric of a Chair: stap 7, afbeelding 1 van 1
    • Sit the chair upright and make sure the fabric is not visible or sagging.
    • If the fabric is visible, remove the staples from the closest corner and pull taut.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Nicole Keller
300 Reputatie
1 Handleiding geschreven
Texas Tech, Team 3-3, Rauch SU 2016 Lid van Texas Tech, Team 3-3, Rauch SU 2016
TTU-RAUCH-SU16S3G3
2 Leden
1 handleiding geschreven
2Gids Commentaar
excellent ways to repair the home furniture. thanks for your ways of writing such a good article about furniture.
Nice post written by Nicole Keller.
http://www.birchi.in/kids-and-baby/kids-...
Birchi In - Antwoord
Thanks a lot! Wish I knew this a couple of weeks ago. Instead, I went and bought two all new 1 seater sofas in Sydney,
Lucas Bergman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 81
Altijd: 25,049
