Ga door naar hoofdinhoud
How to Replace Scott Mountain Bike Handlebars
Wat je nodig hebt
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: stap 1, afbeelding 1 van 2 How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: stap 1, afbeelding 2 van 2
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: stap 2, afbeelding 1 van 1
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: stap 3, afbeelding 1 van 1
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: stap 4, afbeelding 1 van 1
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: stap 5, afbeelding 1 van 1
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: stap 6, afbeelding 1 van 1
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: stap 7, afbeelding 1 van 1
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: stap 8, afbeelding 1 van 1
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
Conclusie
By following these steps, you will have your bike ready in no time.
Sean Slater
139 Reputatie
1 Handleiding geschreven
Cal Poly, Team 23-3, Green Winter 2015 Lid van Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,764
