Ga door naar hoofdinhoud
Coffee Table Metal Drawer Slides Replacement
Wat je nodig hebt
  1. Coffee Table Metal Drawer Slides Replacement, Metal Drawer Slides: stap 1, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement, Metal Drawer Slides: stap 1, afbeelding 2 van 2
    • Make sure to empty the drawer completely before starting the replacement process.
  2. Coffee Table Metal Drawer Slides Replacement: stap 2, afbeelding 1 van 3 Coffee Table Metal Drawer Slides Replacement: stap 2, afbeelding 2 van 3 Coffee Table Metal Drawer Slides Replacement: stap 2, afbeelding 3 van 3
    • Remove the drawer carefully by pulling it out and slowly lifting it upwards until it is out.
  3. Coffee Table Metal Drawer Slides Replacement: stap 3, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 3, afbeelding 2 van 2
    • The drawer and drawer insertion should now look like this when the drawer is out completely.
  4. Coffee Table Metal Drawer Slides Replacement: stap 4, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 4, afbeelding 2 van 2
    • Remove the old gliders by taking the screwdriver and turning it counterclockwise (to the left) until the screw is completely out.
    • Make sure to take out all of the screws on the old gliders before proceeding to the next step.
    • The drill can be used instead of the screwdriver if wanted.
  5. Coffee Table Metal Drawer Slides Replacement: stap 5, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 5, afbeelding 2 van 2
    • This is what the old drawer slides will look like when taken off completely.
  6. Coffee Table Metal Drawer Slides Replacement: stap 6, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 6, afbeelding 2 van 2
    • Measure the new drawer slides.
  7. Coffee Table Metal Drawer Slides Replacement: stap 7, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 7, afbeelding 2 van 2
    • Measure the drawer and the drawer insertion and make sure that the new drawer slides will fit before proceeding to the next step.
  8. Coffee Table Metal Drawer Slides Replacement: stap 8, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 8, afbeelding 2 van 2
    • If applicable, make new markings with the pencil if there needs to be new holes made for the new drawer slides.
    • The drill needs to be used if making new holes for the drawer slides.
  9. Coffee Table Metal Drawer Slides Replacement: stap 9, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 9, afbeelding 2 van 2
    • Make sure everything is lined up nice and neatly.
    • Proceed to screw on the new slides by turning clockwise (to the right) and make sure they are nice and screwed in completely.
  10. Coffee Table Metal Drawer Slides Replacement: stap 10, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 10, afbeelding 2 van 2
    • If applicable, take the pliers and use them to help place the screw in place for screwing.
    • This step is optional.
  11. Coffee Table Metal Drawer Slides Replacement: stap 11, afbeelding 1 van 2 Coffee Table Metal Drawer Slides Replacement: stap 11, afbeelding 2 van 2
    • Use the level and make sure the drawer slides are level before proceeding to the next step.
  12. Coffee Table Metal Drawer Slides Replacement: stap 12, afbeelding 1 van 3 Coffee Table Metal Drawer Slides Replacement: stap 12, afbeelding 2 van 3 Coffee Table Metal Drawer Slides Replacement: stap 12, afbeelding 3 van 3
    • The new drawer slides will look like this when put on completely.
    • The drawer slides on the drawer itself should have the wheels placed on the back.
    • The drawer slides in the drawer insertion should have the wheels placed in the front.
  13. Coffee Table Metal Drawer Slides Replacement: stap 13, afbeelding 1 van 3 Coffee Table Metal Drawer Slides Replacement: stap 13, afbeelding 2 van 3 Coffee Table Metal Drawer Slides Replacement: stap 13, afbeelding 3 van 3
    • Put the drawer back into the drawer insertion by aligning the wheels of each drawer slide.
    • Insert at an angle while slowly pushing the drawer downwards until it is completely in.
    • Make sure that the drawer is opening and closing smoothly.
Eindstreep
Jaley F Scott
217 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 184
