Ga door naar hoofdinhoud
How to Replace Hardwood Flooring
Wat je nodig hebt
  1. How to Replace Hardwood Flooring, How to Replace Hardwood Flooring: stap 1, afbeelding 1 van 1
    • Remove the hardwood, tile, or carpet flooring you are trying to replace to expose the foundation or plywood underneath. The methods will vary depending on the type of flooring that is being removed.
    • Be sure to remove extra fragments of the original flooring and clean the area of any debris.
  2. How to Replace Hardwood Flooring: stap 2, afbeelding 1 van 2 How to Replace Hardwood Flooring: stap 2, afbeelding 2 van 2
    • With a notched trowel, spread the GreenGrip hardwood adhesive over the foundation where you would like to lay the new flooring.
  3. How to Replace Hardwood Flooring: stap 3, afbeelding 1 van 2 How to Replace Hardwood Flooring: stap 3, afbeelding 2 van 2
    • Measure the planks of wood to organize them into a desired pattern, then cut each plank accordingly.
  4. How to Replace Hardwood Flooring: stap 4, afbeelding 1 van 1
    • Carefully place the boards on top of the glue, making sure to push the seams of the planks together.
  5. How to Replace Hardwood Flooring: stap 5, afbeelding 1 van 1
    • Some of the adhesive may come through the seams, so wipe off any excess glue with a wet rag.
  6. How to Replace Hardwood Flooring: stap 6, afbeelding 1 van 1
    • Let the glue cure for 24 hours and enjoy your beautiful new floor!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rori Tyrrell
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 39
Altijd: 829
