Ga door naar hoofdinhoud
How to Repair the Sparker on a Merlion Mini Torch
Wat je nodig hebt
  1. How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: stap 1, afbeelding 1 van 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: stap 1, afbeelding 2 van 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: stap 1, afbeelding 3 van 3
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. How to Repair the Sparker on a Merlion Mini Torch: stap 2, afbeelding 1 van 2 How to Repair the Sparker on a Merlion Mini Torch: stap 2, afbeelding 2 van 2
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. How to Repair the Sparker on a Merlion Mini Torch: stap 3, afbeelding 1 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 3, afbeelding 2 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 3, afbeelding 3 van 3
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. How to Repair the Sparker on a Merlion Mini Torch: stap 4, afbeelding 1 van 2 How to Repair the Sparker on a Merlion Mini Torch: stap 4, afbeelding 2 van 2
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. How to Repair the Sparker on a Merlion Mini Torch: stap 5, afbeelding 1 van 2 How to Repair the Sparker on a Merlion Mini Torch: stap 5, afbeelding 2 van 2
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. How to Repair the Sparker on a Merlion Mini Torch: stap 6, afbeelding 1 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 6, afbeelding 2 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 6, afbeelding 3 van 3
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. How to Repair the Sparker on a Merlion Mini Torch: stap 7, afbeelding 1 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 7, afbeelding 2 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 7, afbeelding 3 van 3
    • Take the empty half of the torch and place it over the other half.
  8. How to Repair the Sparker on a Merlion Mini Torch: stap 8, afbeelding 1 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 8, afbeelding 2 van 3 How to Repair the Sparker on a Merlion Mini Torch: stap 8, afbeelding 3 van 3
    • Use the screwdriver to put the screws back in the torch.
  9. How to Repair the Sparker on a Merlion Mini Torch: stap 9, afbeelding 1 van 2 How to Repair the Sparker on a Merlion Mini Torch: stap 9, afbeelding 2 van 2
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
Conclusie
Congrats! Now you can use your Merlion torch again.
3 andere personen hebben deze handleiding voltooid.
Neel Kogali
200 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-3, Green Fall 2015 Lid van Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 7,623
