Ga door naar hoofdinhoud
How to Repair an Elastic Loop on a Blouse
Wat je nodig hebt
  1. How to Repair an Elastic Loop on a Blouse, How to Repair an Elastic Loop on a Blouse: stap 1, afbeelding 1 van 1
    • Place the broken elastic loop back in its original position on the blouse.
  2. How to Repair an Elastic Loop on a Blouse: stap 2, afbeelding 1 van 1
    • Double thread the needle.
    • Pass the needle through the base of the elastic loop.
  3. How to Repair an Elastic Loop on a Blouse: stap 3, afbeelding 1 van 2 How to Repair an Elastic Loop on a Blouse: stap 3, afbeelding 2 van 2
    • Pass the needle through the stitch line where the elastic loop was originally secured, then back through the base of the elastic loop, at least 6-7 times.
    • Don't pull the thread tight; leave a loop to tie off the thread.
    • Insert your needle through the loops, then pull the thread tight.
  4. How to Repair an Elastic Loop on a Blouse: stap 4, afbeelding 1 van 1
    • Simply cut the thread connected to the needle, and then any dangling threads.
Conclusie
Enjoy your revitalized garment!
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 129
Altijd: 3,563
