Ga door naar hoofdinhoud
How to Repair a Warped LP Record
Wat je nodig hebt
  1. How to Repair a Warped LP Record, How to Repair a Warped LP Record: stap 1, afbeelding 1 van 3 How to Repair a Warped LP Record, How to Repair a Warped LP Record: stap 1, afbeelding 2 van 3 How to Repair a Warped LP Record, How to Repair a Warped LP Record: stap 1, afbeelding 3 van 3
    • Pull your record out of its case, and make sure it is nice and clean.
    • If your record is dirty, you'll want to clean it before starting.
    • Place your clean record in the center of one of the glass panels.
  2. How to Repair a Warped LP Record: stap 2, afbeelding 1 van 2 How to Repair a Warped LP Record: stap 2, afbeelding 2 van 2
    • Gently set the second glass panel on top of the record.
  3. How to Repair a Warped LP Record: stap 3, afbeelding 1 van 3 How to Repair a Warped LP Record: stap 3, afbeelding 2 van 3 How to Repair a Warped LP Record: stap 3, afbeelding 3 van 3
    • Preheat the oven to warm, or 175 degrees Fahrenheit (or 80 Celsius).
  4. How to Repair a Warped LP Record: stap 4, afbeelding 1 van 3 How to Repair a Warped LP Record: stap 4, afbeelding 2 van 3 How to Repair a Warped LP Record: stap 4, afbeelding 3 van 3
    • Glass can shatter when it experiences temperature shock. Be sure that your glass is room temperature or slightly warm before putting it in the oven, so that it doesn't go from very cold to warm too quickly.
    • Slide your record, sandwiched between the two panels of glass, into the oven.
    • Stay with your record and watch it. If you smell anything funny or hear any strange noises, remove your record from the oven.
    • Warm your record in the oven for 2 or 3 minutes.
    • Leaving your record in the oven for longer may melt your record.
  5. How to Repair a Warped LP Record: stap 5, afbeelding 1 van 1
    • Using oven mitts, pull the glass and record assembly out of the oven.
    • Remember that glass can shatter with temperature shock. Do not set your hot glass on a cold granite or tile countertop, or it may shatter!
    • Set the glass on a room temperature table or counter. To protect your surface, place the glass on a potholder or a towel.
  6. How to Repair a Warped LP Record: stap 6, afbeelding 1 van 3 How to Repair a Warped LP Record: stap 6, afbeelding 2 van 3 How to Repair a Warped LP Record: stap 6, afbeelding 3 van 3
    • Weight the glass with heavy books or another flat, heavy object.
    • Leave the record under the weight of the glass and books until it cools completely.
    • When the record is cool, remove it from the glass panels.
Conclusie
Test your vinyl out. If there is still a warp you can repeat the process heating it for just a little longer and weighting it with a heavier object.
41 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.868 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.649 handleidingen geschreven
12Gids Commentaar
just the same process to fix the graphic card of a macbook pro :-D
(Y) great!
Johan Miller - Antwoord
Try this: Get two 1/2" x 12" x 12" polished marble floor tiles. Bathe (the tiles) in hot tap water until heated through. Place record in poly sleeve between the two tiles. Place weights on top - the more the better. Wait for tiles to cool. Repeat as necessary.
BooFaar - Antwoord
BTW - Be sure to dry the tiles after heating.
BooFaar - Antwoord
When I was a kid, I watched my Mom fix a warped record one time by putting it between the plates of glass and setting it in direct sunlight for about 10 minutes. That worked as well.
OriginalSpins - Antwoord
Would sheets of stainless steel work? I don't have access to glass sheets.
Carlos Sanchez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 23
Afgelopen 7 dagen: 155
Afgelopen 30 dagen: 809
Altijd: 165,546
