Inleiding
A good pair of leather boots can be used for whatever and whenever. Be it for style or for work, these boots are meant to last. But like everything else, they'll get worn and broken down. Eventually they won't be the same they once were.
In the case that you've torn your leather boots, this guide is perfect for you. Leather is a hard material to work with. But with our guide, we made it so that you could breath new life into your favorite leather boots using only household or easy to acquire materials.
With just seven steps, your torn leather boots can look and function like brand new!
Wat je nodig hebt
Prepare your leather boot with the listed materials:
After completing all the listed steps above your shoes should be repaired and ready to go. By applying Shoe Goo to your product you have restored the life of your item once again. This procedure is very simple and can be completed several times on the same item.
1Gids Commentaar
Why shoe goo? The end result is a clear semi-clear goo appearance that cant be dyed or colored.
