Ga door naar hoofdinhoud
How to Repair a Silent Wall Clock Mechanism
Wat je nodig hebt
  1. How to Repair a Silent Wall Clock Mechanism, How to Repair a Silent Wall Clock Mechanism: stap 1, afbeelding 1 van 1
    • Using a screwdriver, remove all the screws on the back of the clock.
  2. How to Repair a Silent Wall Clock Mechanism: stap 2, afbeelding 1 van 1
    • Use your fingers to pry up one end of the battery and remove it from the clock.
  3. How to Repair a Silent Wall Clock Mechanism: stap 3, afbeelding 1 van 1
    • Clean the battery terminals in the battery compartment using isopropyl alcohol and a cotton swab.
  4. How to Repair a Silent Wall Clock Mechanism: stap 4, afbeelding 1 van 1
    • Dry the battery terminals with a clean cloth or paper towels so the terminals are not wet when a new battery is being inserted.
  5. How to Repair a Silent Wall Clock Mechanism: stap 5, afbeelding 1 van 1
    • Once the terminals have dried up, remove the glass lens covering the faceplate of the clock to make any adjustments.
  6. How to Repair a Silent Wall Clock Mechanism: stap 6, afbeelding 1 van 1
    • Turn the display face up, ensuring the clock hands do not touch each other.
    • Correct the time by moving the hands of the clock and inserting the new battery.
  7. How to Repair a Silent Wall Clock Mechanism: stap 7, afbeelding 1 van 1
    • Put the faceplate back on and assemble all of the pieces of the clock.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Mohammad Kijera
250 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 216
Altijd: 4,252
