Ga door naar hoofdinhoud
How to Repair a Seam Split in a Sleeping Bag
Wat je nodig hebt
  1. How to Repair a Seam Split in a Sleeping Bag, Identify the repair area: stap 1, afbeelding 1 van 2 How to Repair a Seam Split in a Sleeping Bag, Identify the repair area: stap 1, afbeelding 2 van 2
    • Locate the seam split that needs to be fixed.
  2. How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: stap 2, afbeelding 1 van 3 How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: stap 2, afbeelding 2 van 3 How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: stap 2, afbeelding 3 van 3
    • Find a matching color thread and prepare the needle.
    • Make a double thread and add a little knot at the end.
  3. How to Repair a Seam Split in a Sleeping Bag, Start stitching: stap 3, afbeelding 1 van 3 How to Repair a Seam Split in a Sleeping Bag, Start stitching: stap 3, afbeelding 2 van 3 How to Repair a Seam Split in a Sleeping Bag, Start stitching: stap 3, afbeelding 3 van 3
    • Make sure that the needle is in a position that is perpendicular to the edge of the seam (red arrow).
    • Take turns going up and down following line of the seam.
    • Note For this example we are doing an "invisible" stitch that provides a subtle solution to the split.
  4. How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: stap 4, afbeelding 1 van 3 How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: stap 4, afbeelding 2 van 3 How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: stap 4, afbeelding 3 van 3
    • Secure the stitch by pulling the thread tighter as you go.
    • Continue until you reach the end of the split.
  5. How to Repair a Seam Split in a Sleeping Bag, Clean the area: stap 5, afbeelding 1 van 3 How to Repair a Seam Split in a Sleeping Bag, Clean the area: stap 5, afbeelding 2 van 3 How to Repair a Seam Split in a Sleeping Bag, Clean the area: stap 5, afbeelding 3 van 3
    • Add a knot at the end of the stitch.
    • Use a pair of scissors to clean the loose threads.
  6. How to Repair a Seam Split in a Sleeping Bag, Finished and ready!: stap 6, afbeelding 1 van 2 How to Repair a Seam Split in a Sleeping Bag, Finished and ready!: stap 6, afbeelding 2 van 2
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusie
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10.230 Reputatie
66 handleidingen geschreven
INTERSPORT Lid van INTERSPORT
Community
25 Leden
169 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 291
