Ga door naar hoofdinhoud
How to Repair a Patio Solar Light
Wat je nodig hebt
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: stap 1, afbeelding 1 van 1
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: stap 2, afbeelding 1 van 1
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: stap 3, afbeelding 1 van 1
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: stap 4, afbeelding 1 van 1
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: stap 5, afbeelding 1 van 3 How to Repair a Patio Solar Light: stap 5, afbeelding 2 van 3 How to Repair a Patio Solar Light: stap 5, afbeelding 3 van 3
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: stap 6, afbeelding 1 van 1
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
Conclusie
Miguel Antonio Gonzales
133 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 51
Altijd: 612
