Ga door naar hoofdinhoud
How to Repair a Missing Crochet Stitch
Wat je nodig hebt
  1. How to Repair a Missing Crochet Stitch, How to Repair a Missing Crochet Stitch: stap 1, afbeelding 1 van 1
    • Identify where the repair is needed. Locate where the missing stitch should be.
  2. How to Repair a Missing Crochet Stitch: stap 2, afbeelding 1 van 1
    • Use the crochet hook to hook through the base stitch, (where the missing stitch should have been located), from front to back.
  3. How to Repair a Missing Crochet Stitch: stap 3, afbeelding 1 van 1
    • Create a slip knot with the yarn. Leaving about a 3 inch tail at the end to weave in later.
  4. How to Repair a Missing Crochet Stitch: stap 4, afbeelding 1 van 1
    • Loop the slip knot loop over the hook, and pull the yarn through the base stitch
  5. How to Repair a Missing Crochet Stitch: stap 5, afbeelding 1 van 1
    • Chain stitch the amount of stitches that the missing stitch should be plus one.
    • So if the missing stitch is a single crochet stitch, chain stitch two stitches, if the missing stitch is a double crochet stitch, chain stitch three stitches, and so on.
  6. How to Repair a Missing Crochet Stitch: stap 6, afbeelding 1 van 1
    • Remove the crochet hook and knot the remaining loop. Cut off the yarn leaving another 3 inch tail.
  7. How to Repair a Missing Crochet Stitch: stap 7, afbeelding 1 van 1
    • Thread the darning needle with one of the 3 inch tails. It does not matter which one you choose.
    • Caution: Needle is sharp and should be handled carefully to avoid injury.
  8. How to Repair a Missing Crochet Stitch: stap 8, afbeelding 1 van 1
    • Begin to weave the tail into the surrounding stitches from front to back.
    • Make sure to split the yarn when weaving, for a more seamless look.
  9. How to Repair a Missing Crochet Stitch: stap 9, afbeelding 1 van 1
    • After fully weaving one tail, cut off any excess, and begin weaving the next. Repeating Step 7 through 8.
Conclusie
Rylie Vallo
179 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 132
Altijd: 7,282
