Inleiding
In this guide, I will show you how to fix a large hole in a wall with drywall. If you follow my guide properly, you will not need to hire a professional to fix any type of hole in a wall. This repair requires some practice using a drill, a hand saw, and a box cutter. You will need to know how to use a tape measure to effectively measure the two 2x2 wood. Please refer to the tools used in my project before starting to make you are properly equipped to fix the broken wall.
Caution: Make sure to use care and caution when using the tools described in this guide. Also, when working with drywall, protective gear should be worn. Safety goggles and a dust mask can prevent inhalation of dust particles.
Wat je nodig hebt
Measure the distance between the nearest studs on either side of the hole using a tape measure.
Trace a rectangular/square shape around the hole in pencil.
Use a box cutter to cut along the lines, making the hole into an even rectangular/square shape.
Één opmerking
Thanks for this detailed piece of information! I like this post.
