Ga door naar hoofdinhoud
How to Repair a Hole in a Duvet Insert
Wat je nodig hebt
  1. How to Repair a Hole in a Duvet Insert, How to Repair a Hole in a Duvet Insert: stap 1, afbeelding 1 van 1
    • Remove the duvet cover from the insert and locate the hole.
    Vraag FixBot
    Voeg opmerking toe
  2. How to Repair a Hole in a Duvet Insert: stap 2, afbeelding 1 van 1
    • Cut a piece of scrap fabric slightly larger than the hole.
    Vraag FixBot
    Voeg opmerking toe
  3. How to Repair a Hole in a Duvet Insert: stap 3, afbeelding 1 van 1
    • Insert the fabric inside the hole, making sure the fabric covers the entirety of the opening.
    Vraag FixBot
    Voeg opmerking toe
  4. How to Repair a Hole in a Duvet Insert: stap 4, afbeelding 1 van 1
    • Carefully pin the patch in place, ensuring the entire opening is covered and secure.
    Vraag FixBot
    Voeg opmerking toe
  5. How to Repair a Hole in a Duvet Insert: stap 5, afbeelding 1 van 1
    • Insert thread in the needle hole and tie a slip knot at the end of the thread.
    • Keep extra thread pulled through the needle to prevent it from unthreading. If it does, re-thread and continue.
    Vraag FixBot
    Voeg opmerking toe
  6. How to Repair a Hole in a Duvet Insert: stap 6, afbeelding 1 van 3 How to Repair a Hole in a Duvet Insert: stap 6, afbeelding 2 van 3 How to Repair a Hole in a Duvet Insert: stap 6, afbeelding 3 van 3
    • Insert the needle in one of the corners of your patch, being sure to pierce through both the duvet insert and patch.
    • Continue stitching around the perimeter of the patch with stitches around 1/4 of an inch long until you have reached your previous starting point.
    Vraag FixBot
    Voeg opmerking toe
  7. How to Repair a Hole in a Duvet Insert: stap 7, afbeelding 1 van 2 How to Repair a Hole in a Duvet Insert: stap 7, afbeelding 2 van 2
    • Sew around the hole's edges to secure the duvet insert into the patch to prevent future tearing.
    Vraag FixBot
    Voeg opmerking toe
  8. How to Repair a Hole in a Duvet Insert: stap 8, afbeelding 1 van 3 How to Repair a Hole in a Duvet Insert: stap 8, afbeelding 2 van 3 How to Repair a Hole in a Duvet Insert: stap 8, afbeelding 3 van 3
    • Once finished, tie 1-2 knots and cut the thread off.
    • Make sure to leave 1/4 inch between the cut and the knot to prevent the knot from coming undone.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
Ben Arnold-Galati
187 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 Lid van UC Davis, Team 3-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G3
3 Leden
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 72
Altijd: 704
