Ga door naar hoofdinhoud
How to Repair a Hole in a Bed Rest Pillow
Wat je nodig hebt
  1. How to Repair a Hole in a Bed Rest Pillow, How to Repair a Hole in a Bed Rest Pillow: stap 1, afbeelding 1 van 1
    • Identify the location and size of the hole.
  2. How to Repair a Hole in a Bed Rest Pillow: stap 2, afbeelding 1 van 1
    • Insert the thread into the needle.
    • Option: You can double the thread to create a knot for a more accurate threading process.
  3. How to Repair a Hole in a Bed Rest Pillow: stap 3, afbeelding 1 van 2 How to Repair a Hole in a Bed Rest Pillow: stap 3, afbeelding 2 van 2
    • To begin sewing, insert the needle at either end of the hole.
  4. How to Repair a Hole in a Bed Rest Pillow: stap 4, afbeelding 1 van 1
    • Sew the material together until the hole is completely patched.
  5. How to Repair a Hole in a Bed Rest Pillow: stap 5, afbeelding 1 van 1
    • Once the hole is patched, use the scissors to cut any excess string.
Conclusie
Once your done, the hole should be completely shut and the pillow will be back to good use.
Zachary Head
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 62
Altijd: 1,997
