Ga door naar hoofdinhoud
How to Repair a Hair Clip with a Detached Spring
Wat je nodig hebt
  1. How to Repair a Hair Clip with a Detached Spring, How to Repair a Hair Clip with a Detached Spring: stap 1, afbeelding 1 van 2 How to Repair a Hair Clip with a Detached Spring, How to Repair a Hair Clip with a Detached Spring: stap 1, afbeelding 2 van 2
    • Place the two pieces of the hair clip together.
    • The circles on the top of the clip should align.
  2. How to Repair a Hair Clip with a Detached Spring: stap 2, afbeelding 1 van 2 How to Repair a Hair Clip with a Detached Spring: stap 2, afbeelding 2 van 2
    • Tie the rubber band around the hair clip to secure the pieces in place.
  3. How to Repair a Hair Clip with a Detached Spring: stap 3, afbeelding 1 van 1
    • Insert the pin halfway into the circles on the top of the clip.
  4. How to Repair a Hair Clip with a Detached Spring: stap 4, afbeelding 1 van 1
    • Place the spring next to the inserted pin with the two edges facing upwards.
  5. How to Repair a Hair Clip with a Detached Spring: stap 5, afbeelding 1 van 1
    • Use the pliers to push the pin through the spring and remaining holes.
  6. How to Repair a Hair Clip with a Detached Spring: stap 6, afbeelding 1 van 3 How to Repair a Hair Clip with a Detached Spring: stap 6, afbeelding 2 van 3 How to Repair a Hair Clip with a Detached Spring: stap 6, afbeelding 3 van 3
    • Take the rubber band off and test the repair.
Conclusie
8 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
Where do I get the springs from?
Jessica stone - Antwoord
Where can I get new pins?
Nancy P. - Antwoord
Did anyone get answers for the springs and pin questions? Where do we get those?
Julianna Di Miceli - Antwoord
From Hungary and I found springs for sale in a designated shop online, but they're insanely overpriced. One spring goes for 1.49 in USD for which I can buy a brand new hair clip for... Wild how much they charge for a tiny piece of bent wire!
Georgina - Antwoord
Me encantooo!!! Si no que no le puse la coleta eso por que mi traba era una flor y me molestabaa!! Gracias por el tutorial, me sirvió mucho...
lucía - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 50
Afgelopen 7 dagen: 462
Afgelopen 30 dagen: 2,056
Altijd: 96,940
