Inleiding
Use this guide to repair a power supply cable that has frayed at the power inlet.
Wat je nodig hebt
Inspect the frayed power supply end for spots that you can cut off the connector insulation without damaging the wires.
Cut the insulation off the connector using wire cutters, scissors, or a sharp knife.
Open the Sugru pack, remove the material, and press it around the connector to make a new connector insulator. It is recommended that your new sheath extends at least .5" past the damaged area.
You have approximately 30 minutes to work the Sugru. Then allow about 24 hours for it to fully cure.
Soo Informative ❤️
But Sir when i repair my laptop charger
After opening my laptop The charger is not charging my laptop only Showing "plugged in your charger"
How i fix this
29 andere personen hebben deze handleiding voltooid.
