Ga door naar hoofdinhoud
How to Repair a Dangle Earring
Wat je nodig hebt
  1. How to Repair a Dangle Earring, How to Repair a Dangle Earring: stap 1, afbeelding 1 van 1
    • Clean the jump ring of the earring and the earring itself.
    • This step is optional.
  2. How to Repair a Dangle Earring: stap 2, afbeelding 1 van 2 How to Repair a Dangle Earring: stap 2, afbeelding 2 van 2
    • Take the jump ring with the two small needle-nose pliers.
    • Gently open the jump ring using the needle nose pliers.
  3. How to Repair a Dangle Earring: stap 3, afbeelding 1 van 2 How to Repair a Dangle Earring: stap 3, afbeelding 2 van 2
    • Take the top part of the earring with your dominant hand.
    • Put the jump ring through the top part of the earring.
    • You can hold the jump ring with a small needle-nose pliers with your non-dominant hand.
  4. How to Repair a Dangle Earring: stap 4, afbeelding 1 van 2 How to Repair a Dangle Earring: stap 4, afbeelding 2 van 2
    • Pass the earring through the opening of the jump ring.
    • Make sure that both parts of the earring face the same direction.
  5. How to Repair a Dangle Earring: stap 5, afbeelding 1 van 2 How to Repair a Dangle Earring: stap 5, afbeelding 2 van 2
    • To close the jump ring, use both of the needle nose pliers.
    • Use your dominant hand to close the space in the jump ring.
    • Try to keep your non-dominant hand still.
  6. How to Repair a Dangle Earring: stap 6, afbeelding 1 van 2 How to Repair a Dangle Earring: stap 6, afbeelding 2 van 2
    • Make sure that the jump ring is closed.
    • Hold the earring up to make sure it's secure.
Conclusie
To just change a clasp that it was not broken, follow these instructions in reverse order.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 1,141
