Ga door naar hoofdinhoud
How to Repair a Daiso Earphone Case with a Torn Fabric Hinge
Wat je nodig hebt
    1. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge, How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 1, afbeelding 1 van 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge, How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 1, afbeelding 2 van 2
      • Unzip the case and lay it flat.
      • Use scissors to cut off any unraveled fabric or stray threads.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 2, afbeelding 1 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 2, afbeelding 2 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 2, afbeelding 3 van 3
      • Push the end of the thread through the eye of the needle.
      • Wet the end of the thread to make it easier.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 3, afbeelding 1 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 3, afbeelding 2 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 3, afbeelding 3 van 3
      • Unravel the thread from the spool.
      • Double up the thread as you unravel. Continue unraveling until you have about 15-20 inches in total.
      • Pull out more thread than you need.
      • Cut the thread where the ends meet.
      • Adjust the folded thread until both sides are as equal as possible.
      Vraag FixBot
      Voeg opmerking toe
    4. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 4, afbeelding 1 van 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 4, afbeelding 2 van 2
      • Tie a knot about an inch from the end of the thread.
      • You may need to make more knots. Doing so will prevent the thread from slipping out of the fabric hinge in the steps ahead.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 5, afbeelding 1 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 5, afbeelding 2 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 5, afbeelding 3 van 3
      • Align the three layers exactly as they’d be if the layers were intact.
      • To maintain the alignment more precisely, use sewing pins.
      • Position the needle to estimate how the needle will enter. Before inserting, the needle should keep a centimeter distance from the edge of the damaged fabric hinge. After inserting, it should intercept the fabric that runs parallel to the zipper teeth.
      • Pull the needle through all three layers of the hinge until the end knot stops against the fabric.
      • Insert the needle slowly and keep your fingers away from the exit point.
      Vraag FixBot
      Voeg opmerking toe
    6. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 6, afbeelding 1 van 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 6, afbeelding 2 van 2
      • If the zipper is torn, tuck the zipper back where it belongs. Hold the three layers in place.
      • The end of the zipper is inside the spine.
      • Shift the needle down the spine, toward the center of the case, vertically aligned with your previous pass.
      • Make sure the needle will pass through all three layers of fabric.
      • Pass the needle through the layers of fabric until the thread is tight without bunching the fabric. This is your first stitch.
      • Be careful not to push the needle through the zipper teeth.
      Vraag FixBot
      Voeg opmerking toe
    7. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 7, afbeelding 1 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 7, afbeelding 2 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 7, afbeelding 3 van 3
      • Position the needle at the spot where you made the first pass. It's the first entry point (farther from the center of the spine).
      • Pull the needle through until the thread is tight.
      • You should now have a stitch on both sides.
      Vraag FixBot
      Voeg opmerking toe
    8. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 8, afbeelding 1 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 8, afbeelding 2 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 8, afbeelding 3 van 3
      • Move the needle perpendicular to the stitch you made, going towards the black fabric of the case.
      • Repeat steps 5-8, making rows of stitches until the fabric is secure.
      • About three rows of stitches are enough to secure the fabric, but you can make more for extra strength.
      Vraag FixBot
      Voeg opmerking toe
    9. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 9, afbeelding 1 van 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 9, afbeelding 2 van 2
      • The final stitches will look like this. There will be a row of singular stitches on both sides.
      • Make sure you pull the final stitch so that the thread that is interwoven into the spine is firm and snug.
      Vraag FixBot
      Voeg opmerking toe
      • Make a knot to secure the stitches. The knot should be as close to the exit point as possible.
      • Use your finger or the needle to keep the thread flat as you close and tighten the knot.
      • Make several knots the same way you may have done in step 4 so the stitches will not come undone.
      Vraag FixBot
      Voeg opmerking toe
    10. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 11, afbeelding 1 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 11, afbeelding 2 van 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: stap 11, afbeelding 3 van 3
      • Cut off the excess thread on both sides of the earphone case. You may leave a small amount if you'd like.
      Vraag FixBot
      Voeg opmerking toe
      • The final case should zip up with ease. The fabric hinge should be secure.
      • Gently pull the two sides away from each other to test the strength of the hinge.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
Natalie Whitmer
205 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-3, Whithaus Spring 2025 Lid van UC Davis, Team 3-3, Whithaus Spring 2025
UCD-WHITHAUS-S25S3G3
2 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 663
