Ga door naar hoofdinhoud
How to Repair a Crack on a Vittorazi Moster Exhaust
Wat je nodig hebt
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: stap 1, afbeelding 1 van 3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: stap 1, afbeelding 2 van 3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: stap 1, afbeelding 3 van 3
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: stap 5, afbeelding 1 van 2 How to Repair a Crack on a Vittorazi Moster Exhaust: stap 5, afbeelding 2 van 2
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: stap 6, afbeelding 1 van 1
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: stap 7, afbeelding 1 van 1
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: stap 8, afbeelding 1 van 2 How to Repair a Crack on a Vittorazi Moster Exhaust: stap 8, afbeelding 2 van 2
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: stap 9, afbeelding 1 van 2 How to Repair a Crack on a Vittorazi Moster Exhaust: stap 9, afbeelding 2 van 2
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: stap 10, afbeelding 1 van 2 How to Repair a Crack on a Vittorazi Moster Exhaust: stap 10, afbeelding 2 van 2
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: stap 11, afbeelding 1 van 1
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 1,070
