Ga door naar hoofdinhoud
How to Repair a Burnt Wire for a Light Globe
Wat je nodig hebt
  1. How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: stap 1, afbeelding 1 van 2 How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: stap 1, afbeelding 2 van 2
    • Use a flathead screwdriver to remove the two 3 mm screws from the power adapter.
  2. How to Repair a Burnt Wire for a Light Globe: stap 2, afbeelding 1 van 1
    • If needed, clean the power adapter's shell as much as possible.
  3. How to Repair a Burnt Wire for a Light Globe: stap 3, afbeelding 1 van 1
    • Use wire cutters to cut the wires to equal lengths.
  4. How to Repair a Burnt Wire for a Light Globe: stap 4, afbeelding 1 van 1
    • Use wire strippers to carefully peel the wire cord to expose 2 cm of wire.
  5. How to Repair a Burnt Wire for a Light Globe: stap 5, afbeelding 1 van 1
    • Slide the shell back into the wire cord, past the exposed copper wires.
  6. How to Repair a Burnt Wire for a Light Globe: stap 6, afbeelding 1 van 3 How to Repair a Burnt Wire for a Light Globe: stap 6, afbeelding 2 van 3 How to Repair a Burnt Wire for a Light Globe: stap 6, afbeelding 3 van 3
    • Grab the terminal of the power adapter and loosen the 3 mm screws of the terminal if needed.
    • Wrap one exposed copper wire around one loosened 3 mm screw and tighten the screw immediately.
    • Repeat the second bullet point for the second copper wire.
  7. How to Repair a Burnt Wire for a Light Globe: stap 7, afbeelding 1 van 2 How to Repair a Burnt Wire for a Light Globe: stap 7, afbeelding 2 van 2
    • Push the shell back into the terminal so that the terminal is protected by the shell.
    • Grab the 3 mm screws that were taken out in the first step and re-screw them into the shell.
  8. How to Repair a Burnt Wire for a Light Globe: stap 8, afbeelding 1 van 2 How to Repair a Burnt Wire for a Light Globe: stap 8, afbeelding 2 van 2
    • Plug in the power adapter into a functioning power outlet.
    • The light globe should now successfully turn on!
Eindstreep
HarpreetGill
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 454
