Ga door naar hoofdinhoud
How to Repair a Broken/Cracked Soccer Shin Pad
Wat je nodig hebt
  1. How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: stap 1, afbeelding 1 van 3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: stap 1, afbeelding 2 van 3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: stap 1, afbeelding 3 van 3
    • Start by properly cleaning the dirt off the soccer shin pad with a coarse brush.
    • Be sure to clear any dust from inside the crack as well, as any dirt left inside can interfere with the bonding agent
  2. How to Repair a Broken/Cracked Soccer Shin Pad: stap 2, afbeelding 1 van 1
    • Put one clamp on either side of the crack.
  3. How to Repair a Broken/Cracked Soccer Shin Pad: stap 3, afbeelding 1 van 1
    • Align the clamps so that there are no spaces throughout the crack.
  4. How to Repair a Broken/Cracked Soccer Shin Pad: stap 4, afbeelding 1 van 2 How to Repair a Broken/Cracked Soccer Shin Pad: stap 4, afbeelding 2 van 2
    • Make sure clamps are aligned with the crack before you apply the resin solution
    • Apply the resin solution onto the crack, being sure to fully cover the crack on both sides.
    • Let the solution dry for at least 30 minutes.
    • But we suggest leaving the shin pad out for 24 hours for best results.
  5. How to Repair a Broken/Cracked Soccer Shin Pad: stap 5, afbeelding 1 van 3 How to Repair a Broken/Cracked Soccer Shin Pad: stap 5, afbeelding 2 van 3 How to Repair a Broken/Cracked Soccer Shin Pad: stap 5, afbeelding 3 van 3
    • Remove the clamps slowly so that no damage will be done to the shin pad.
  6. How to Repair a Broken/Cracked Soccer Shin Pad: stap 6, afbeelding 1 van 2 How to Repair a Broken/Cracked Soccer Shin Pad: stap 6, afbeelding 2 van 2
    • Clean the extra resin solution that sits on top of the shin pad.
    • Your shin pad is now ready to use.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 286
