Ga door naar hoofdinhoud
How to Repair a Broken Windowsill
Wat je nodig hebt
  1. How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: stap 1, afbeelding 1 van 3 How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: stap 1, afbeelding 2 van 3 How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: stap 1, afbeelding 3 van 3
    • Remove any loose, splintered, or jagged wood by hand.
  2. How to Repair a Broken Windowsill: stap 2, afbeelding 1 van 3 How to Repair a Broken Windowsill: stap 2, afbeelding 2 van 3 How to Repair a Broken Windowsill: stap 2, afbeelding 3 van 3
    • Grab three straight sections of cardboard.
    • Apply Vaseline to one side of each section of cardboard by hand. Vaseline will prevent the wood filler from sticking to the cardboard.
  3. How to Repair a Broken Windowsill: stap 3, afbeelding 1 van 1
    • Hold one section of cardboard underneath the corner needing repair with the Vaseline side facing up.
  4. How to Repair a Broken Windowsill: stap 4, afbeelding 1 van 2 How to Repair a Broken Windowsill: stap 4, afbeelding 2 van 2
    • Apply wood filler to the corner by squeezing the tube.
  5. How to Repair a Broken Windowsill: stap 5, afbeelding 1 van 3 How to Repair a Broken Windowsill: stap 5, afbeelding 2 van 3 How to Repair a Broken Windowsill: stap 5, afbeelding 3 van 3
    • Position the other two sections of cardboard on either side of the corner to help shape the filler into a right angle. Place the sides with the Vaseline on them toward the filler.
    • Use a putty knife or plastic butter knife to smooth filler if needed.
  6. How to Repair a Broken Windowsill: stap 6, afbeelding 1 van 1
    • Remove the cardboard sections before the filler dries completely.
    • Allow the filler to dry for approximately six hours. The filler may take less time to dry if repairing a smaller section of the apron. For dime sized reparations, the filler will take approximately two hours to dry.
  7. How to Repair a Broken Windowsill: stap 7, afbeelding 1 van 2 How to Repair a Broken Windowsill: stap 7, afbeelding 2 van 2
    • Sand the filler with 120 grit sandpaper until it is satisfactory.
    • Repeat steps 4-7 if the corner is not the desired shape.
  8. How to Repair a Broken Windowsill: stap 8, afbeelding 1 van 2 How to Repair a Broken Windowsill: stap 8, afbeelding 2 van 2
    • Paint the finished corner with the desired shade of paint.
    • Allow the paint 3 hours to completely dry.
Conclusie
Once the paint dries, the project is complete.
Julia Byrd
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 255
Altijd: 5,431
