Ga door naar hoofdinhoud
How to Repair a Broken Playhouse Door
Wat je nodig hebt
  1. How to Repair a Broken Playhouse Door, How to Repair a Broken Playhouse Door: stap 1, afbeelding 1 van 1
    • Label each piece of wood with a number.
    • The door in this guide has seven panels, so I'll be labeling them 1 through 7.
  2. How to Repair a Broken Playhouse Door: stap 2, afbeelding 1 van 3 How to Repair a Broken Playhouse Door: stap 2, afbeelding 2 van 3 How to Repair a Broken Playhouse Door: stap 2, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove all the screws so that each wood panel is separated.
  3. How to Repair a Broken Playhouse Door: stap 3, afbeelding 1 van 2 How to Repair a Broken Playhouse Door: stap 3, afbeelding 2 van 2
    • Gather all the individual wood panels and line them up in their numbered order so that the door looks complete.
  4. How to Repair a Broken Playhouse Door: stap 4, afbeelding 1 van 2 How to Repair a Broken Playhouse Door: stap 4, afbeelding 2 van 2
    • Apply wood glue to each panel of wood where it intersects with another piece.
    • You may want to keep a towel or napkin nearby to wipe off any excess glue.
  5. How to Repair a Broken Playhouse Door: stap 5, afbeelding 1 van 2 How to Repair a Broken Playhouse Door: stap 5, afbeelding 2 van 2
    • Attach clamps to the wood panels where the glue was applied. Place one clamp on each end.
    • It might be easiest to glue and clamp two wood panels together at a time and then attach all the pieces together once the glue dries.
    • Keep the clamps on the wood panels until the glue is completely dry. It takes about 24 hours for the glue to fully cure.
  6. How to Repair a Broken Playhouse Door: stap 6, afbeelding 1 van 3 How to Repair a Broken Playhouse Door: stap 6, afbeelding 2 van 3 How to Repair a Broken Playhouse Door: stap 6, afbeelding 3 van 3
    • After removing the clamps, use the Phillips screwdriver to put the screws back in the same spots they were removed from.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 97
