Ga door naar hoofdinhoud
How to Repair a Broken Jump Ring
Wat je nodig hebt
  1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: stap 1, afbeelding 1 van 1
    • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
    • Make sure that the ring's opening is not blocked by the pliers.
  2. How to Repair a Broken Jump Ring: stap 2, afbeelding 1 van 1
    • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
  3. How to Repair a Broken Jump Ring: stap 3, afbeelding 1 van 1
    • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
  4. How to Repair a Broken Jump Ring: stap 4, afbeelding 1 van 2 How to Repair a Broken Jump Ring: stap 4, afbeelding 2 van 2
    • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
  5. How to Repair a Broken Jump Ring: stap 5, afbeelding 1 van 2 How to Repair a Broken Jump Ring: stap 5, afbeelding 2 van 2
    • Insert your earring into the opening of the jump ring.
  6. How to Repair a Broken Jump Ring: stap 6, afbeelding 1 van 2 How to Repair a Broken Jump Ring: stap 6, afbeelding 2 van 2
    • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
    • Make sure that the gap is closed tight!
Conclusie
Your earrings are ready to be worn again!
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 1,059
