Ga door naar hoofdinhoud
How to Repair Maytag MRT311FFFE Frozen Ventilation System
Wat je nodig hebt
  1. How to Repair Maytag MRT311FFFE Frozen Ventilation System, How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 1, afbeelding 1 van 2 How to Repair Maytag MRT311FFFE Frozen Ventilation System, How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 1, afbeelding 2 van 2
    • Set the temperature switch in the refrigerator to “OFF.”
  2. How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 2, afbeelding 1 van 2 How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 2, afbeelding 2 van 2
    • Remove all items from the freezer, including the freezer shelf.
  3. How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 3, afbeelding 1 van 2 How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 3, afbeelding 2 van 2
    • Use a 6 mm Allen key to remove the two 6.0 mm screws securing the freezer’s interior back cover.
  4. How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 4, afbeelding 1 van 1
    • Gently pull the freezer’s interior back cover and set it face down on the bottom of the freezer.
    • It won’t completely come off since there’s a cable connected to the back cover.
    • Be careful not to dislodge any wires.
  5. How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 5, afbeelding 1 van 1
    • Check the ventilator’s compartment for frozen blockages.
    • You can use a flashlight for a better look, or fish something long and thin into the compartment; if it hits something, it’s because it’s blocked with ice.
  6. How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 6, afbeelding 1 van 1
    • Turn the hairdryer onto its "hot" or "warm" setting, then point it directly into the frozen ventilator’s compartments until the ice melts, clearing the vents.
    • Be careful not to overheat the surrounding plastic.
  7. How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 7, afbeelding 1 van 1
    • Replace the back cover.
    • Reinstall the two 6 mm screws with a 6 mm Allen key.
    • Replace the freezer shelf.
  8. How to Repair Maytag MRT311FFFE Frozen Ventilation System: stap 8, afbeelding 1 van 1
    • Reorganize the items in a way that doesn’t block the vent’s airflow.
Conclusie
Your fridge should now be able to maintain cold temperatures again!
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 46
Altijd: 1,271
