Ga door naar hoofdinhoud
How to Repair Arm Gapes
Wat je nodig hebt
  1. How to Repair Arm Gapes, How to Repair Arm Gapes: stap 1, afbeelding 1 van 1
    • Gather the supplies needed.
  2. How to Repair Arm Gapes: stap 2, afbeelding 1 van 2 How to Repair Arm Gapes: stap 2, afbeelding 2 van 2
    • Grab your measuring tape.
    • Measure from the middle of the breast to the under arm part.
  3. How to Repair Arm Gapes: stap 3, afbeelding 1 van 3 How to Repair Arm Gapes: stap 3, afbeelding 2 van 3 How to Repair Arm Gapes: stap 3, afbeelding 3 van 3
    • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
    • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
    • Mine was about 0.5 inches. (Slide three)
  4. How to Repair Arm Gapes: stap 4, afbeelding 1 van 3 How to Repair Arm Gapes: stap 4, afbeelding 2 van 3 How to Repair Arm Gapes: stap 4, afbeelding 3 van 3
    • Connect both of the dots from the breast to the two dots you marked near the underarm.
    • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
  5. How to Repair Arm Gapes: stap 5, afbeelding 1 van 1
    • Sew across.
    • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
  6. How to Repair Arm Gapes: stap 6, afbeelding 1 van 1
    • Lastly, cut the access off.
    • Then flip it inside out.
    • And your done!
Conclusie
Thank you for taking the time to read this.
Danielle Fontanos
133 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-6, Kershman Fall 2023 Lid van CSU Los Angeles, Team 5-6, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G6
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 27
Altijd: 100
