Ga door naar hoofdinhoud
How to Repair A Wet Book
Wat je nodig hebt
  1. How to Repair A Wet Book, How to Repair A Wet Book: stap 1, afbeelding 1 van 1
    • Be cautious when handling wet books, as books are very fragile when wet and you can accidentally damage front cover, pages, and/or spine.
    • If you do not have time to fix it, immediately put it in a Ziplock bag and place in freezer until you're ready. When you are ready to fix it, lay it on the table and leave it until it thaws.
    • Cover table with plastic sheet or newspapers.
  2. How to Repair A Wet Book: stap 2, afbeelding 1 van 1
    • Lay the book down with the front cover facing up. Place a paper towel over the cover and gently press down on the book.
  3. How to Repair A Wet Book: stap 3, afbeelding 1 van 2 How to Repair A Wet Book: stap 3, afbeelding 2 van 2
    • Be very careful when opening the book, as the spine is very fragile.
    • Gently opening the book to a shallow angle, place paper towels every 10-20 pages in the front half of the book. Place a paper towel on the front cover and press down gently.
  4. How to Repair A Wet Book: stap 4, afbeelding 1 van 2 How to Repair A Wet Book: stap 4, afbeelding 2 van 2
    • Similarly to step 3, gently open the book to a shallow angle and place paper towels in every 10-20 pages towards the last half of the book. Place a paper towel on the front cover and press down.
  5. How to Repair A Wet Book: stap 5, afbeelding 1 van 1
    • Stand the book up, heads or tails, with the pages fanned out.
  6. How to Repair A Wet Book: stap 6, afbeelding 1 van 1
    • To speed up the drying process, leave a fan blowing on it.
  7. How to Repair A Wet Book: stap 7, afbeelding 1 van 2 How to Repair A Wet Book: stap 7, afbeelding 2 van 2
    • If after the book has dried the pages are wavy, lay the book flat and place a board on top of it, along with a couple of heavy books (on top of the board) to help flatten them out. Leave it like this until the pages are completely flattened.
  8. How to Repair A Wet Book: stap 8, afbeelding 1 van 1
    • Great job! The book is now restored to its original condition. Happy reading!
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Lizzy Cox
241 Reputatie
1 Handleiding geschreven
2Gids Commentaar
because im in middle school. and it is sters full with wet books
Hazen Harwood - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 125
Altijd: 2,097
