Ga door naar hoofdinhoud
How to Repair A Hole In Curtains
Wat je nodig hebt
  1. How to Repair A Hole In Curtains, How to Repair A Hole In Curtains: stap 1, afbeelding 1 van 2 How to Repair A Hole In Curtains, How to Repair A Hole In Curtains: stap 1, afbeelding 2 van 2
    • Examine the hole and open it gently so as to not cause any tearing.
    • Cut any loose threads that have frayed around the tear.
    • Be careful when using scissors. They are sharp and may cause injury.
  2. How to Repair A Hole In Curtains: stap 2, afbeelding 1 van 2 How to Repair A Hole In Curtains: stap 2, afbeelding 2 van 2
    • Use your scissors to cut a piece of fusible interfacing.
    • Make sure this piece is slightly larger than the hole in your curtain.
  3. How to Repair A Hole In Curtains: stap 3, afbeelding 1 van 1
    • Place the ripped curtain face down on the ironing board.
  4. How to Repair A Hole In Curtains: stap 4, afbeelding 1 van 2 How to Repair A Hole In Curtains: stap 4, afbeelding 2 van 2
    • Place the fusible interfacing adhesive side down.
    • This side will have raised bumps on it
  5. How to Repair A Hole In Curtains: stap 5, afbeelding 1 van 1
    • Preheat the iron to the temperature stated on the instructions for the fusible interfacing.
    • Some fusible interfacing may require either a steam setting or a dry setting.
  6. How to Repair A Hole In Curtains: stap 6, afbeelding 1 van 3 How to Repair A Hole In Curtains: stap 6, afbeelding 2 van 3 How to Repair A Hole In Curtains: stap 6, afbeelding 3 van 3
    • Iron over the interfacing until it sticks to the fabric.
    • If the fabric is delicate you may want to place a protective cloth over the patch before ironing.
    • Be careful when using an iron. They can burn the fabric or cause serious injury.
Conclusie
Now your curtain is as good as new! Fusible interfacing cannot be removed once it is attached to the fabric, so be careful when applying it so you can repair your curtains successfully.
Heather Brody
133 Reputatie
1 Handleiding geschreven
Marist, Team S1-G4, Chaterdon Spring 2021 Lid van Marist, Team S1-G4, Chaterdon Spring 2021
MARS-CHATERDON-S21S1G4
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 83
Altijd: 2,242
