Ga door naar hoofdinhoud
How to Repair A Broken Hip In A Plastic Doll
Wat je nodig hebt
  1. How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: stap 1, afbeelding 1 van 2 How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: stap 1, afbeelding 2 van 2
    • Determine where your doll is broken: is it at the knee? Hip? Arm?
    • If it’s broken at the knee, as marked in the second photo, unfortunately this guide will not help as it is a different kind of joint.
  2. How to Repair A Broken Hip In A Plastic Doll: stap 2, afbeelding 1 van 2 How to Repair A Broken Hip In A Plastic Doll: stap 2, afbeelding 2 van 2
    • If the ball is still inside the leg, remove it with pliers.
  3. How to Repair A Broken Hip In A Plastic Doll: stap 3, afbeelding 1 van 1
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter.
    • Do not leave fire unattended. The metal will be hot, so please don't touch it with your bare skin.
  4. How to Repair A Broken Hip In A Plastic Doll: stap 4, afbeelding 1 van 1
    • With the hot sewing needle, make a small hole in the center of the broken off ball. Make sure the needle is straight.
    • This may take a few attempts and a few needles.
    • Heating up the plastic will result in some fumes. Perform this step in a well ventilated area.
  5. How to Repair A Broken Hip In A Plastic Doll: stap 5, afbeelding 1 van 1
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter. (This is a repeat of Step 3.)
  6. How to Repair A Broken Hip In A Plastic Doll: stap 6, afbeelding 1 van 2 How to Repair A Broken Hip In A Plastic Doll: stap 6, afbeelding 2 van 2
    • With the hot sewing needle, make a small hole in the peg of the hip. Make sure the needle is straight. Leave the pin inside.
  7. How to Repair A Broken Hip In A Plastic Doll: stap 7, afbeelding 1 van 2 How to Repair A Broken Hip In A Plastic Doll: stap 7, afbeelding 2 van 2
    • Remove the pin from the broken off ball joint with a pair of pliers.
  8. How to Repair A Broken Hip In A Plastic Doll: stap 8, afbeelding 1 van 2 How to Repair A Broken Hip In A Plastic Doll: stap 8, afbeelding 2 van 2
    • Using the pliers, cut the pin in the hip section to the appropriate length to fit into the hole made from Step 6.
    • Test the needle length by fitting the ball joint pieces together. The needle should be completely covered.
    • The needle will go flying when you cut it, so direct it away from your face and other precious objects.
  9. How to Repair A Broken Hip In A Plastic Doll: stap 9, afbeelding 1 van 1
    • Optional: remove any excess burnt plastic from the ball joint.
  10. How to Repair A Broken Hip In A Plastic Doll: stap 10, afbeelding 1 van 3 How to Repair A Broken Hip In A Plastic Doll: stap 10, afbeelding 2 van 3 How to Repair A Broken Hip In A Plastic Doll: stap 10, afbeelding 3 van 3
    • Remove the pin from the hip and apply super glue to the end.
    • Insert the pin back into the hole.
    • When you reinsert the pin, some glue may come out. Leave it for Step 11.
  11. How to Repair A Broken Hip In A Plastic Doll: stap 11, afbeelding 1 van 1
    • Push the ball onto the pin. Press together for 1 minute to set the glue.
    • The glue will set in 1 minute but it will take 24 hours to fully cure.
  12. How to Repair A Broken Hip In A Plastic Doll: stap 12, afbeelding 1 van 1
    • Apply glue around the seam for extra reinforcement.
  13. How to Repair A Broken Hip In A Plastic Doll: stap 13, afbeelding 1 van 2 How to Repair A Broken Hip In A Plastic Doll: stap 13, afbeelding 2 van 2
    • Now with the ball joint secured into the pelvis, carefully pop the leg back into the hip.
    • The doll's leg should now move as normal!
Conclusie
To reassemble your device, follow these instructions in order.
Lee Brunkhardt
232 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-1, Andersen Winter 2023 Lid van UC Davis, Team 3-1, Andersen Winter 2023
UCD-ANDERSEN-W23S3G1
5 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 119
Altijd: 1,654
