Ga door naar hoofdinhoud
How to Remove a Wheel Lock Without a Key
Wat je nodig hebt
  1. How to Remove a Wheel Lock Without a Key, Wheel Lock: stap 1, afbeelding 1 van 3 How to Remove a Wheel Lock Without a Key, Wheel Lock: stap 1, afbeelding 2 van 3 How to Remove a Wheel Lock Without a Key, Wheel Lock: stap 1, afbeelding 3 van 3
    • Clean the wheel lock to make sure there is no debris on the surface of the lock.
  2. How to Remove a Wheel Lock Without a Key: stap 2, afbeelding 1 van 2 How to Remove a Wheel Lock Without a Key: stap 2, afbeelding 2 van 2
    • Find a 12-point socket that barely fits over the wheel lock.
    • The socket should not be loose enough to revolve around the wheel lock.
  3. How to Remove a Wheel Lock Without a Key: stap 3, afbeelding 1 van 2 How to Remove a Wheel Lock Without a Key: stap 3, afbeelding 2 van 2
    • Hold the socket in place.
    • Use a hammer to hit the socket until it is tight around the lock.
    • Gloves are recommended to prevent hand injury.
  4. How to Remove a Wheel Lock Without a Key: stap 4, afbeelding 1 van 2 How to Remove a Wheel Lock Without a Key: stap 4, afbeelding 2 van 2
    • Unscrew the socket using the socket wrench.
    • Turn left to loosen. If you cannot turn the wrench easily, get a longer wrench for more torque.
  5. How to Remove a Wheel Lock Without a Key: stap 5, afbeelding 1 van 3 How to Remove a Wheel Lock Without a Key: stap 5, afbeelding 2 van 3 How to Remove a Wheel Lock Without a Key: stap 5, afbeelding 3 van 3
    • Now that the wheel lock is off, it will be stuck to the socket.
    • Insert the screwdriver into the square-opening on top of the socket.
    • Hit the top of the screwdriver with the hammer a few times until the lock falls out of the socket.
  6. How to Remove a Wheel Lock Without a Key: stap 6, afbeelding 1 van 3 How to Remove a Wheel Lock Without a Key: stap 6, afbeelding 2 van 3 How to Remove a Wheel Lock Without a Key: stap 6, afbeelding 3 van 3
    • Grab a regular wheel nut.
    • Screw on the wheel nut by hand.
    • Use the tire iron to tighten the wheel nut.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Hesham Annamer
244 Reputatie
1 Handleiding geschreven
4 opmerkingen
Hi, I have a 05 dodge dakota that has 4- 8 spline thin wall deep socket lug nuts on them. I have went to every tire/mechanic shop and tool store. I really need to get these off so I can change my breaks!!
If there's anything or any advice you can give on how to get these suckers off, I would greatly appreciate it 🙏🏽
As my husband has been trying for over a week now!!
SK Seid - Antwoord
Those are really tricky to get out, i remember welding on a 17mm nut properly and then using impact to get that out son years ago, last option in usually drilling out the whole stud and socket, both options are really frustrating especially if you have expensive rims. If u can hammer on a socket a impact gun will get that out.
Nirap Singh -
I was skeptical, but this did in fact work on my 2005 Honda CRV spare tire wheel lock. I used a 3/4 inch 12 point socket. Hammered it on and it came off easily. Can't get the wheel lock nut out of the socket, but well worth losing a socket to get off the nut.
Atomic Night Light - Antwoord
I recently had the same issue. I thought I lost the key lock for my BMW. I contacted a vendor and was told they could replace it, if I sent them a picture of it. My son was taking the picture when he saw it in the loug bolt. I believe its been there for a few months .
Bill D - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 138
Afgelopen 7 dagen: 971
Afgelopen 30 dagen: 4,013
Altijd: 108,481
