Ga door naar hoofdinhoud
How to Remove a BIOS Password From Acer Laptops
  1. How to Remove a BIOS Password From Acer Laptops, How to Remove a BIOS Password From Acer Laptops: stap 1, afbeelding 1 van 1
    • Turn on your laptop.
    • Log into WindowsOS.
  2. How to Remove a BIOS Password From Acer Laptops: stap 2, afbeelding 1 van 1
    • Once you log in, click on your web browser and visit the Acer driver download page: https://www.acer.com/us-en/support/drive...
    • The website will ask for your laptop SNID number, located on the bottom of your Acer laptop below the lower bar code.
    • Once you have entered the SNID, you will be prompted to download the BIOS firmware.
    The link here is broken, could you please provide us with a new one?, thanks!
    Penny - Antwoord
    Thanks for your comment. Here is a new link: https://www.acer.com/ac/de/CH/content/dr...
    Tim Hochstrasser -
  3. How to Remove a BIOS Password From Acer Laptops: stap 3, afbeelding 1 van 1
    • Once the BIOS firmware is downloaded, install the “7-Zip Extractor”.
    • To install the "7-Zip Extractor" right click on the BIOS firmware. Hover over"7-Zip" in the drop bar, another drop bar will appear, click on "Extract files".
    • If an error message appears saying: "7-Zip Extractor cannot extract the entire .exe file," try running the "firmware.exe" file.
    • Press "CTRL" and "S" simultaneously to save your progress.
  4. How to Remove a BIOS Password From Acer Laptops: stap 4, afbeelding 1 van 1
    • Simultaneously press the ''Windows" and "R" key so that a text box pops up and enter "%temp%" in the text box.
    • Find the folder that the "firmware.exe" files have been temporarily extracted to. Right click on all of the files and copy them.
  5. How to Remove a BIOS Password From Acer Laptops: stap 5, afbeelding 1 van 1
    • Open the file named "platform.ini".
    • A new page will appear. Along the left side of the new page find "Password=0” and replace it with "Password=1".
  6. How to Remove a BIOS Password From Acer Laptops: stap 6, afbeelding 1 van 1
    • Run the “InsydeFlash.exe” file and complete the screen instructions.
    • Once done with screen instructions, restart your laptop and the BIOS password should be gone.
Conclusie
Hopefully, you have successfully deleted your BIOS password. If you were not successful, please see the guide in the introduction for further details, or seek help from Acer customer service.
7 andere personen hebben deze handleiding voltooid.
Ethan
151 Reputatie
1 Handleiding geschreven
14 opmerkingen
There is no ini file in the firmware update , acer nitro 515-53
huleo57 - Antwoord
How to unlock Acer bios
Robert Rids - Antwoord
How to unlock Acer bios 4750
Acer e1-431. BIOS forget
prakash computers - Antwoord
Bios password forget
Does this really work out because I’m going to try it out now
Because I have something like this in front of me right now..
Akande Similoluwa - Antwoord
upgraded to latest bios already before trying. So cant do the flash unless new bios comes out. Get an error message to say you have the latest bios, cant go back either !
A M - Antwoord
The page cannot be found!
Jana janka - Antwoord
Thanks for letting us know, Jana!
The link was replaced and it works now.
Penny -
What must I do on this site? There's nothing about "SNID". It's so terrible !!! I will destroy this &&^&^$^ Laptop !!!
Hi, Jana
You can go to this section of the site https://www.acer.com/in-en/support/drive... and write your SNID there.
Then just go on from Step 2 on this guide.
Penny -
Bei meinem SP714-51-M339 ist plötzlich das BIOS gesperrt. seit dieser Zeit lässt sich auch kein Life-Linux vom USB-Stick mehr starten. Ich habe die Änderung in der plattform.ini versucht. Leider lässt sich die beschriebene Methode sich nicht akurat zu Ende führen. in dem Verzeichnis befindet sich keine InsydeFlash.exe. Weiß einer warum oder kennt jemand die richtige Methode für meinen Spin?
MfG
HeGe
He_ge@web.de
HeGe - Antwoord
Ähnlich bei mir (mit Acer Concept D): Plötzlich ist ein Admin-Passwort drinnen, obwohl ich mich nicht erinnern kann, es jemals (vor 2 Jahren) gesetzt zu haben.
Im extrahierten EXE finde ich das erwähnte Programm nicht, stattdessen sollte es vermutlich "H2OFFT-Wx64.exe" tun (in der GUI lese ich was von Insyde). Beim Start wird das System überprüft, dann kommt "The version of ROM file is the same as that of BIOS." und das Programm schließt sich anschließend. Was kann ich machen?
MfG
Günther
G. Zinsberger -
I tried this. In my case the file name to run was H2OFFT-Wx64.exe. I modified platform.ini according to the guide. The bios was flashed but the password remained. :-(
muhkuh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 71
Afgelopen 7 dagen: 534
Afgelopen 30 dagen: 2,347
Altijd: 49,272
