Ga door naar hoofdinhoud
How to Remove Rust from a Gardening Shovel
Wat je nodig hebt
  1. How to Remove Rust from a Gardening Shovel, How to Remove Rust from a Gardening Shovel: stap 1, afbeelding 1 van 1
    • Fill a large container with water.
  2. How to Remove Rust from a Gardening Shovel: stap 2, afbeelding 1 van 1
    • Add an ample amount of distilled white vinegar.
  3. How to Remove Rust from a Gardening Shovel: stap 3, afbeelding 1 van 1
    • Soak the shovel for at least 10 minutes, but ideally for 24 hours.
  4. How to Remove Rust from a Gardening Shovel: stap 4, afbeelding 1 van 1
    • Scrub the shovel with a scrub brush.
    • Scrub with a tooth brush.
    • Scrub with a Brillo pad.
  5. How to Remove Rust from a Gardening Shovel: stap 5, afbeelding 1 van 1
    • Refill the large container with fresh water.
  6. How to Remove Rust from a Gardening Shovel: stap 6, afbeelding 1 van 1
    • Add 1-2 cups of baking soda.
  7. How to Remove Rust from a Gardening Shovel: stap 7, afbeelding 1 van 1
    • Soak the shovel for 15 minutes.
  8. How to Remove Rust from a Gardening Shovel: stap 8, afbeelding 1 van 1
    • Rinse the shovel.
  9. How to Remove Rust from a Gardening Shovel: stap 9, afbeelding 1 van 1
    • Dry the shovel completely.
  10. How to Remove Rust from a Gardening Shovel: stap 10, afbeelding 1 van 1
    • Oil the shovel with coconut oil.
Conclusie
Repeat process until rust is completely removed.
Brigette B
181 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 105
