Ga door naar hoofdinhoud
How to Remove Makeup Stain from Shirt
Wat je nodig hebt
  1. How to Remove Makeup Stain from Shirt, How to Remove Makeup Stain from Shirt: stap 1, afbeelding 1 van 1
    • Place a white napkin or rag under the shirt to avoid making a mess or colour transfer into the garment.
  2. How to Remove Makeup Stain from Shirt: stap 2, afbeelding 1 van 2 How to Remove Makeup Stain from Shirt: stap 2, afbeelding 2 van 2
    • Pour micellar water over the stain
    • Micellar water can be replaced by any kind of water-based makeup remover.
    • Do not use an oil-based makeup remover as it will permanently damage the shirt.
  3. How to Remove Makeup Stain from Shirt: stap 3, afbeelding 1 van 2 How to Remove Makeup Stain from Shirt: stap 3, afbeelding 2 van 2
    • Pat the stain dry with the napkin/rag from Step 1.
    • Do not use Kleenex tissues as they will fall apart and make a mess by sticking to the fabric.
  4. How to Remove Makeup Stain from Shirt: stap 4, afbeelding 1 van 1
    • Wash the shirt in cold water with the detergent of your choice.
  5. How to Remove Makeup Stain from Shirt: stap 5, afbeelding 1 van 1
    • Pour detergent over the stain. Pour baking soda or powder over the soap.
    • The recommended measurement is 1/4 of a teaspoon of baking soda/powder but you may use more if the stain is larger.
  6. How to Remove Makeup Stain from Shirt: stap 6, afbeelding 1 van 1
    • Scrub the paste into the shirt with a toothbrush.
  7. How to Remove Makeup Stain from Shirt: stap 7, afbeelding 1 van 1
    • Let rest for 15 minutes.
  8. How to Remove Makeup Stain from Shirt: stap 8, afbeelding 1 van 1
    • Wash the shirt in cold water followed by lukewarm water.
  9. How to Remove Makeup Stain from Shirt: stap 9, afbeelding 1 van 1
    • Let the shirt air dry and iron it if necessary.
Conclusie
Let the shirt air dry and iron as needed.
Ariana Rabbaninejad
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 42
Altijd: 362
