Ga door naar hoofdinhoud
How to Remove MacBook ID Activation Lock by T203
Video overzicht
  1. How to Remove MacBook ID Activation Lock by T203, Activation Lock: stap 1, afbeelding 1 van 1
    • T203 includes two tools: T203 USB flash drive and T203 ROM seat. T203 is mainly used to remove the EFI lock, pin code lock, and bypass the iCloud activation lock of 2018-2020 MacBook with the T2 chip.
  2. How to Remove MacBook ID Activation Lock by T203: stap 2, afbeelding 1 van 3 How to Remove MacBook ID Activation Lock by T203: stap 2, afbeelding 2 van 3 How to Remove MacBook ID Activation Lock by T203: stap 2, afbeelding 3 van 3
    • First of all, let’s turn on the MacBook. Activation lock is showing.
    • Then we will use T203 to unlock the activation lock. Turn the MacBook off firstly. The MacBook model is A1989. Detach the motherboard and find the T2 ROM chip. Set the temperature and airflow of the Hot Air Gun at 425 °C and 3 respectively to remove the T2 ROM chip.
  3. How to Remove MacBook ID Activation Lock by T203: stap 3, afbeelding 1 van 3 How to Remove MacBook ID Activation Lock by T203: stap 3, afbeelding 2 van 3 How to Remove MacBook ID Activation Lock by T203: stap 3, afbeelding 3 van 3
    • Attach the chip to the specialized seat of T203. Align pin 1 of the chip with pin 1 of the seat.
    • Connect T203 to computer and open “Programmer Software” folder. Begin writing unlock data.
    • Unplug T203. Then we install the chip on the motherboard. Solder the chip back on the motherboard with Hot Air Gun at 425 °C and airflow 3.
  4. How to Remove MacBook ID Activation Lock by T203: stap 4, afbeelding 1 van 3 How to Remove MacBook ID Activation Lock by T203: stap 4, afbeelding 2 van 3 How to Remove MacBook ID Activation Lock by T203: stap 4, afbeelding 3 van 3
    • Put the motherboard back on the MacBook.
    • After the data have been written, the MacBook is in DFU mode. The MacBook is unable to turn on. Connect the MacBook to another MacBook with a data cable. Please plug the cable into the left bottom Type-C.
    • Open Apple Configurator 2. Right click to select “Restore”. Begin restoring.
  5. How to Remove MacBook ID Activation Lock by T203: stap 5, afbeelding 1 van 2 How to Remove MacBook ID Activation Lock by T203: stap 5, afbeelding 2 van 2
    • The lock sign on the screen indicates that the restoring has finished. Long press start button with one hand. Press touch panel with another hand.
    • The touch panel is unresponsive, which means that the MacBook is turned off. Release the power button and then press the power button again. Press Control-Option-Shift-Power button to get the MacBook into DFU mode.
  6. How to Remove MacBook ID Activation Lock by T203: stap 6, afbeelding 1 van 2 How to Remove MacBook ID Activation Lock by T203: stap 6, afbeelding 2 van 2
    • Plug in the T203 USB to read the MacBook data. The MacBook data is successfully read if the Touch Bar has shown some images.
  7. How to Remove MacBook ID Activation Lock by T203: stap 7, afbeelding 1 van 3 How to Remove MacBook ID Activation Lock by T203: stap 7, afbeelding 2 van 3 How to Remove MacBook ID Activation Lock by T203: stap 7, afbeelding 3 van 3
    • Bypassing activation lock is ongoing.
    • We can see that bypassing has succeeded. Click “Cancel”. The device is successfully activated. Unplug the data cable. Press the power button. The MacBook shows no system. Turn the MacBook off. Press Command-R. Enter the system installation interface. Start reinstalling.
    • Connect the MacBook with power. The ID of the MacBook is successfully removed. The activation has succeeded.
Conclusie
29 andere personen hebben deze handleiding voltooid.
REWA
18.459 Reputatie
55 handleidingen geschreven
43Gids Commentaar
hello this solution is it for complete unlock or bypass device ?
Lukáš Kadeřábek - Antwoord
For Bypass only
Dammy Dammy -
Does this change the serial number to the macbook you are unlocking?
bdyer9999 - Antwoord
I’m so glad our questions are getting answered :/
hello, i forgot my ID on my macbook pro a2338
Jhervel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 157
Afgelopen 7 dagen: 1,034
Afgelopen 30 dagen: 4,380
Altijd: 152,217
