Inleiding
Do you have silverware scratches on your dishware? Do you wish your dishes looked as good as new? A dinner plate with scratches may seem old or unattractive. Renew the appearance of your dishes with this easy technique.
Wat je nodig hebt
Shake some of the "Bar Cleaner's Friend" powder onto the back of the plate to make sure that it does not damage the coloring.
Wet the sponge and wipe the plate to see if the product is damaging to your plate.
If it is, then stop usage immediately and rinse your plate to reduce damage.
If the product is not damaging, then continue use on the top of the plate.
Now you have a plate that looks good as new! To maintain the appearance of your dishware, simply use the same process described in this guide when scratches appear again.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
I can’t get Bartender’s friend, but it inspired me to try a ceramic stove top cleaner. It worked like a charm. I was going to throw those dishes away. I have had them for 25 years. Now they will last at least another 15…
